old oil stank of petrol and had about a litre too much in, bear in mind i run twin pumps and 1000cc sards. wont take long at 8.0.1 afr to do that.was changed after afr set and prior to dyno run,car was never driven with the contaminated oil in the motor
sounds very bad to me.....fuel is a rubbish lubriant, almost as bad as coolant :D
but assuming you changed it, most of it was removed (no oil cooler?), and the problem was fixed that may not be it.....you don't have the oil that just came out of it?
  • Replies 76
right guys a further development. looks like we have looking in the wrong place. i now suspect something has gone through the engine.from where i am not sure. below are pictures of the head on number 5 the one that spun and number 5 piston crown,, i was running a 1mm headgasket. question is whatever caused these marks would it be enoug on a 1mm gasket to jam the piston enough to cause the crank to hit the bearing momentarily?.
i have stripped the turbo, nothing wrong there?. had a look in the exhaust there is some very small shiny magnetic fragments?. any idea where something that could do this had got in from..
The indentations look a lot like spark plug electrode mate.
I once left mine at a "reputable" tuner for dyno-ing after a forged rebuild and was not happy with the results, (less power everywhere with higher specs) and after lots of head scratching I pulled it out and found the pricks had melted plugs in it (dash 8's) and simply put new ones in it and gave it back to me.
yeah +1 for detonation.
would also explain why the bearing has gone on no5 too.
You would think it would be across the board but and evident in all cylinders. I suppose if no5 injector had issues there's a possibility.
What do the other cylinders looke like?
odd thought... but had you used a die grinder on or near your intercooler piping or anything that would have been open on the intake setup weather it be plenum, TB, ic piping, comp housing, intake pipe....
that pitting either looks like the result of ceramic bits off a sparkplug or metal filings from something not being cleaned properly after working on it..
hi Cartman, no mate if i ever do anything like that the cars is not in the garage, you can see some die grinding work on the head in the pics, i have over the weekend fully ported and polished the head. its away now for a light skim. now the piston tops are cleaned of they almost look as good as the day they went in..lol
all the valve guides in 1 piece? ive seen the inlets fracture and do similar damage.
that wont be the cause of the damage. its not detonation.
to only dammage 1 bearing its only oil contanimation. fron the look of it something has been sitting in the crank and got loosed. did you have the crank grubscrewed when it was first built?
of have you recently put on a oil cooler?
hi t04gtr
cars has always had a 19row oil cooler fitted.feedsin the top and drain at the bottom, the oil filter is mounted low on a remote so when you do and oil change the cooler empties too.
no grub screw mate, collar was sweated on and has never moved
no valve guides damaged at all.
i find it hard to believe det after looking at the pistons..
still wondering why?.
bernie
If you had lost an engine at 900klm you would feel the same way as Marko. The engine in question was a low revving item that was never put under stress...N1 went bang.
GTRNUR...correct...the mains are all shiny from eating rod bearing material.
So what kind of revs was it pulling and under what circumstances did it go bang? Drag/circuit?
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
