hello ive just got a nisstune ecu installed and tuned. ive had a highflow on the car for the past 5 months, and have had compressure surge problems from scratch. i thought we could make it better with a tune but no go
what it is doing is when i try and make booste bellow 3 grand in fifth, when ime over taking, it just goes into surge at about 5psi even on light throtle, it will do it in 4th at low rpm aswell.
if i go through the gears hard there is no problem.
i rang the place that did my turbo and they seem to think they put a t04b wheel in it, is that to big, would that cause this problem
its an r33 gtst s2
nistune
standard plumbback bov
14psi
https://www.sau.com.au/forums/topic/315027-compressure-surge-highflow-turbo/
do some reading on compressor surge, understand what it is and this will give you the answer
the likely causes of compressor surge are mangled hiflows / mismatched specs like you mentioned
your kinda stuck with it i would say, did the place who did it offer any option to fix it or change the wheel
i mean if you've ordered a hiflow and been given a botched hiflow, what good is that? they should fix it or did you ask for that specific wheel ?
yeah get them to fix it and make sure you check their policy if they botch it again
ie if they "fix" it and you pay a cost then you get it back and its the same surging, what is the next step and who pays?
Probably a mismatach of wheel sizes (Comp/exhaust wheel) - i.e. too small exhaust wheel and/ore too large compressor wheel. Changing one of these should work to reduce the surge.
Though it's likely you/they will need to provide a new housing. Probably the easiest fix would be to put in a smaller compressor wheel, however this would mean you need a new housing as the one you have would be machined out too much.
Otherwise you get a bigger exhaust wheel (more lag though) that would mean they machine out more of your housing.
Sounds like they haven't done one before, so as paul said if you pay extra money you would want something in writing that they will rectify it for free.
And each time you pull it on and off (or pay a workshop) is an inconvenience to you.
Edited by benl1981
VG30 are hard to come by and they will be laggier due to the op6 larger housing (common to R34gtt and z32 3.0T VG30DET 300zx's).. $150 is a fair bit if you only need the housing (for an R33 turbo - for a vg30 you'll be lucky to get one for that price due to demand). Can you find a blown one for cheaper? Shouldnt be more than about $50 if the bearings are shot.
VG30 will make more power but you will lose response (probably about 300rpm, although it doesn't sound like much it will feel a bit more doughy, a really good tune may help this a bit). For 250rwkw and under R33 housing. For the extra 20rwkw go the R34 housing.
As turbo dave aid if you get the larger housing machined out to suit the exhaust wheel you have may solve your compressor surge issue.
Depends how much mucking around your willing to do and what sort of responsibility is the company taking on e.g. how much are they going to charge to swap wheels, machine out housing, balance etc?
T04B wheel is a 16 fin 58T 71mm wheel is not really good for high flow purposes. and likely to surge as the exducer of it is too short for the inducer. But either way you shouldn't be getting surge at low RPMs.
also depends on the type of turbine wheel you got there. Do you have a photo of the turbo with booth wheels?
We have .63 and .82 turbine housings to suit OEM setups if needed.
I have a vg30 high flow, has a t04b compressor wheel and the guy they built it was getting surge if it hit 15psi below 4000rpm so he back cut the exhaust wheel so it would hit 15 psi just on 4000rpm.
so what do guys think would b the best way to go.
smaller comp wheel, and new comp cover
or different exhaust housing.
Looks/sounds like a general mechanical mismatch between turbine and compressor, and then the whole unit to the engine. that 8 x 2 blade T04B impeller can push a lot of air very early, so a"tight" turbine that spools it quickly will lead to surge. But that comp is not overly efficient either, so going to a bigger A/R turbine might only partly achieve your goals for a performance application.
Firstly be sure the BOV is operating correctly.
Then, I'd say consult directly with Stao and get the turbocharger spec'd correctly if needed. They have a few different specs that should hit the target you want.
just pulled my intake pipe of to find a 16 blade comp wheel, 8 front and 8 sort of back a bit that aint rite is it.
obviously these flow heaps at low shaft speeds, what about when it is high reving.
thanks for the input to guys..
As a 8 x 2 blade impeller, yep it's right for what it is (a TO4B). Is it "right" or "best" for a RB25 spec high flow? Check earlier comments by Stao.
You'll likely find that impeller is something used around a diesel application. Good flow capacity but the flow maps lay over to the right compared to (say) a high speed impeller like the 71mm GT35 as used on a GT-RS or GT2835R. Check and you'll see they run a 6 x 2 blade impeller.
The extra blades on yours give it that low end pumping ability, but it runs into choke and efficiency falls away as shaft speeds get up. Same thing you'll see happen with water pump impellers, jet ski impellers, and boat propellors.
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
