ive bought a nistune board and an rb20 ecu to use in my r33 and ive got a frequency switch from jaycar to control the vct.
ive been told the range is around 1800rpm - 4700rpm. should i go straight off this or should i do dyno runs with and without the vct to get it exact?
from what ive read the vct solenoid has a constant ignition feed and a switched earth. so really all i have to do is run an earth to one side of the NO contact and run a wire to the vct solenoid from the other side of the NO contact on the switch and then adjust the switch so that it turns on and off at the desired rpm? and of course have a 12v ignition and earth going into the switch to give it power, and tap into the rpm signal and run that to the switch?
also when adjusting the the actual switch to turn on and off at the desired rpm can i be free revving the car in neutral?
i used a MSD RPM activated switch, it just adds a ground between s certain rpm range than than removes it after that point is reached, effectly turning on , than off the vct soleniod. the msd cost like 80 dollers and looks nice, it can also be used for nitrous and other things
i heard the msd ones were a couple of hundred bucks otherwise i would of got one of them.
crans just check that the battery is alrite 1st, even if u hook up a jumper pack or something then if its still not charging check the basic conections (main pos and neg from battery, and the connections on the starter and alternator) if thats all good then get someone to rev the engine while u got your meter on there if the voltage still isnt going up then its your alternator, most likely brushes or diodes
The answer is yes. Since you have gone to so much trouble you may as well get the ideal settings from the dyno. Of course you can set it near enough beforehand and adjust it when you get the opportunity on a dyno.
The frequency switch will only switch it on or off at a set rpm. it isn't a window switch like the msd unit.
You could get it to work that way by playing with the hysterisis but that would only work in one direction (either increase or decrease in frequency) which makes it useless becasue your switch point would have to be at 1100 or so which you just don't see in regular driving unless you stop.
Dave has it right. Just got mine working(not tuned 100% tho) if you are driving revs hit 1200 vct activates you give it some throttle revs climb past 4700 vct turns off you quickly tap the breaks and revs drp below 4700 it dosn't re activate. you have to let the revs drop below 1200 fo it to be able to activate again.
How much for the msd unit and where can i order from?
my home made unit was just tested looks promising just need to sort out a grounging issue which stops the tacho in the dash from working.
rpm counter is slightly off but that dosnt matter quick fix should be a capacitor on the rpm feed to filter out noise
you just set it so it switches the vct off at 4800 or so but it's on the rest of the time. Having it on at idle isn't ideal but doesn't hurt anything from what i've read, if anything it cleans up the idle if you have biggish cams as it reduces the overlap.
Thats how i'll be setting mine up anyway.
I would have liked to get a greddy mss which would have done it properly and is a compact nice looking unit but they are discontinued.
I used the Msd unit when i changed from auto to man and couldn't get the nvcs to work and u can't go wrong with this unit...
Simple to install and adjust to any rpm up to 10k if u wish
U don't want it on at idle bc it makes it idle like shit .... dont know how it will react with bidder cams tho
Ended up sellin it tho bc its difference was verrrrrrrrry minimal on my stock set up
http://cgi.ebay.com/ebaymotors/MSD-8969-DI...S-/300399015408
r u talkin about the jaycar unit?
let us know how it goes n if theres any probs,
nah i built and connected the jaycar unit and it useless it uses low high triggers not rpm window.
A friend is helping me build out own vtc controller using a amtel cpu
yeah, msd went up in price i got mine brand new from local dealer for 90 dealers delivered the next day heh. msd is simple though like 4 wires; pwr, grnd; rpm signal; and one that either adds or removes the ground to the item you wanted to use it on. its liek a gray wire if you want it to have power in the rpm range or a blue wire if you dont want it to have power in that rpm range, quick and easy
  • 3 weeks later...
Just received my MSD RPM window switch. Good looking little unit. Still working on my home made unit but really need the car running properly.
Just reading that it can only ground 2.5amps will i need a relay connected or is the vct load 2.5amps or under?
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
