Item Description: JDM N14 Pulsar GTi SR18DE Auto Transmission with VLSD, rebuilt completely from scratch:
Custom Valve Body
Custom Heavy Duty Clutch Packs and Hubs
Custom Heavy Duty Band and Drum 12mm wider than standard
Custom Torque Converter with Heavy Duty Lock Up Clutch and Roller Bearings
Custom machined Servo Assembly
Trans Go SR18DE Sentra Shift Kit
I spent 3 years and more money than I can bare to describe on the development of this transmission. It will come with both VLSD driveshafts (very rare), one is almost brand new. It will also be supplied with both gearbox mounts and brackets which are different to locally-delivered items.
Website: N/A
Item Condition: Worked well the last time it was driven with (approx. 2 months ago.) See extra info.
Reason for selling: Abandoned project. Unsuitable for application and going manual.
Price and price conditions: $1500 ono. Will freight at buyer's expense.
Extra Info: Unsuitable for high power/high torque turbo applications without more development. Should more than cope with high power N/A and stock power/stock torque turbo applications. It had no issues with a stock SR20DET behind it for approx. 20,000km's of street driving. I would suggest inspecting the transmission before installation for wear. It has done approx. 1500km since it was last rebuilt, however it was having issues with slipping due to heat.
Also, please don't insult my intelligence with low-ball offers. The transmission, driveshafts and mounts alone are worth what I am asking (stock), let alone more than $10,000 I spent on development.
I can get pictures for anyone genuinely interested, otherwise it looks like an automatic transmission.
  • 4 weeks later...
  • 1 month later...
  • 3 months later...
  • 2 months later...
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
  • 1 month later...
  • 1 month later...
  • 11 months later...
  • 3 weeks later...
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
