OK - the task here requires a bit of imagination.
Where have you seen a Skyline? Photoshop your favourite car into your favourite location or historical event.
Points for humor ;)
Here's a quick example to get you going:
James
  • Replies 120
I can't compete with that, that's sheer quality James. :)
Have you ever wondered what will become of your car in years to come?
This one is pretty weak, :Oops: but i'm not very good at this, just having some fun!
