  • Replies 157
They were ripping up all the bitty along Port Wakefield road before Bolivar today
so if you can bypass this bit it might save you some stonechips. Might just be heading
southbound on way back so check it out - if you can come out from kings road you will
miss the mess.......
Have a good day out there guys.
Should we bring extra fuel, tools, fluids etc like we did at the track day or what. Is there going to be sheds open?
you shouldn't need extra fuel as you won't be going flat out round and round all day like the other trackdays. you won't need tools, ramps, etc unless you're planning to break your car tomorrow.
full tank of fuel, comfortable clothing and (driving) shoes should be all that you need. take all loose objects out of your car beforehand (and check under the seats) so that crap doesn't roll out and fly out when you're on the track.
check your tire pressures (cold) tonight or first thing tomorrow. set at 36-38psi cold for 17-18" street tires.
we like to start at 0830am sharp so make sure that you get to Mallala by 8am. a few of the instructors will be there from 8am.
stop mucking around with your cars now and make sure that you get a good night's sleep! :P
Definatly had a good day, great course to do and learnt quite alot. It's amazing how much you need to know and how much you need to think and remember when taking corners and going through apexes. Overall good day out on the track and it was great weather for it. Thanks to all who organized it all.
Oh and there were only 9 of us out there which in a way was good as we each had more runs.
Michael(GoAhead) took photos and should be putting them up tomorrow.
Mark, the fella with the Liberty just popped round and showed me some pics, look forward to seeing more. It really is a fantastic day, I don't understand why a course like this isn't compulsory for learner drivers.
Here's a question for ya Nik, you gonna do the HP day in November?
I'll upload the photos I took tomorrow when I get on the computer, I'm just on my phone, was an amazing day, cooked the brakes but was good, supra boys were good to, had some clean rides, even thou the v8 supra was a little different, highly recommend the course to anyone
Massive thanks to Kim for organizing the day and giving us the opportunity to be there
Need better fluid mister, shouldn't have cooked them on that day
Yep, I wasn't the only one thou, everything was going fine till we started doing laps, pulling up from 160 at the end of the back straight.... Oh well, learning curve for the next track day.... Which will be when Luke? Haha
i will definitely be keen for the HP track day....hopefully with more power and a little bit more handling work done to it :laugh:
what brake setup did you run??? the same thing happened to me on similar day like yours mate.....after that i changed pretty much everything......i went with QFM A1RM brake pads, penrite sin 600 brake fluid, HEL braided brake lines with RDA slotted rotors and that setup went awesome throughout the last SAU:SA grip day.....lasted the whole day of full onb thrashing :rolleyes:
yeah i found out the same thing lol....a wicked street setup can only hack 3-5 hot laps in a row before giving up lol.....hence why i went with something that can be used on the street and track....
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
