Can New Front Tyres Be Used With Old Rears?
maxzugkraft
 Share
Can anyone advise whether I can replace the front tyres without replacing rears?
My front insides are worn out. There is a 1cm strip of "no tread" about 1cm from the inside edge. The middle to the outsides are still good. Not even down to the wear indicators yet. It seems such a waste to replace them.
However the rears are fine.
So I was thinking of replacing the fronts only with the same Bridgestones.
Will it trigger the TPMS warning or stuff up the 4wd mechanism?
Thank you in advance.
Won't cause any probs other than your worn rears may not have as much traction as your new fronts making the car more biased towards oversteer and just may affect when VDC cuts in. Other than that the slight difference in diameter etc wont affect anything and TPMS definitely wont be affected. Nissan fitted two new fronts on mine and if it really did matter Im sure they would have changed all of them....
While on this subject, has anyone arrived at a wheel alignment setting for a daily driver that doesn't result in premature inside edge wear? Even at min neg camber, if I compensate by extra toe in all it does is just add wear to the outside in addition to the excessive inside edge wear. The middle of the tread remains untouched.... Is the only way to find some aftermarket means of reducing my front neg camber?
Edited by fungoolie
Thanks for the responses guys.
My alignment settings for road-use was smack in the middle of the recommended range.
I guess I could ask them to push it to the maximum allowable positive camber next time.
Might not like the traction loss around corners though.
I have been "hanging on" to my original set of Bridgestones for too
long & they are totally useless at the track now. They have 12000km
on them & still have plenty of tread but they have been melted from
3 track days & today was the last straw.
Seems like the Dunlops are the go to replace them - what other alternatives
do we have now?
go the dunlops munro, I think they are the best option on a set of stock wheels for mixed track and street use. if you have trouble sourcing them for good money, call Taleb Tyres in Sydney, speak to Ali and tell him I put you in touch. he'll do a good price. when I last checked for a replacement set for my old 35 his price was on par with me buying them wholesale in japan and shipping them out myself.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
