just gona post a update for anyone who is interested finshed fitting the kit today and after alot of cutting of the bar with the grinda eventally got a pretty decent fit with the lgihts on
Where did you get the bar from? and how much was it if you dont mind my asking?
I got it from carmate.com.au great service arrives in 1 buiness day and it costed 405 all up with shipping
would you recommend carmate?
i want to buy a gtr style bar, how did you find the fitting of your bar?
Yeah I would recomend them there good serivce price good and delivery is fast, ive bought rear from just jap and skirts psi parts and happy with all there fitments , so yeah the fitment is pretty good on this front bar just had to hack into it to make room for the front mount and also the light fitting but yeah with actrual lining up to the guards if the bar doesnt foul with intercooler or anything it lines up prety well
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
