Hesitation Upto 2200 Rpm
Fark this... mental health day it is tomorrow. Booked Luddenham lol Is the clutch fked? yep Do I need to fix that in tank venturi? yep Will I do any of the above? No -
Dye *should* work on the _cloth_ but not on the hard vinyl. That said, it's a mixture of both of these things. You probably have a sedan, and want a coupe as the coupe got all the black interior and the sedan is silver. I was planning on just taking the lot to a trimmer as you've noticed it's a mix of cloth, hard plastic, and bits of metal that need to change colour so I wager you will need all sorts of different, complimentary skills to actually make it work.
By soviet_merlin · Posted
This one is coming up on the weekend! Fingers crossed the weather holds up. I have never done this one so it better work out this year -
Sorry I think that must be another language thing, globe = light bulb
Man, you guys are like an all knowing encyclopedia.. how do you guys know how to fix everything?? but thanks. i will try to trace this wiring today. What is this globe thing you are referring too? Globe Power Supply? Are you referring to the light bulb?
