1992 R32 skyline 2 door.
never boosted, has cat back exhaust and pod filter.
Recently serviced at boost worx
had a dyno power run that came back with 153kws.
very healthy, strong motor.
I have the dyno chart..
No bubbles in dash!!!
started getting a few parts together but have now decided to move on to something different.
114xxx kms
cat back exhaust
pod filter
tien HA coilovers (still have the standard springs/shocks)
17" light weight meshies
dvd player with splits in doors and 6x9s in the back run off an amp
cam cover gaskets replaced recently
only thing that needs to be done is the water pump as its leaking.
i have a new timing belt to put on at the same time as the water pump,
was just going to get turbo tune to do the water pump and timing belt and do the adjustable cam gears at the same time so it could be tuned aswell
i have just swapped the standard turbo for one off a s2 rb25.
it will also come with (not fitted)
a 3" dump/front pipe
xtream heavy clutch
front mount kit
boost controller
and the standard turbo
$10500 ono. may consider swaps for late model commodore or similar
Edited by Jbone
https://www.sau.com.au/forums/topic/315217-sa-1992-r32-gtst/
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
