Hey all! Selling a few parts off my smashed skyline. It was a r33 gts-t, series 1, 4 door (automatic). I haven't got any pictures as of yet but if pictures are required feel free to ask. Everything is in great working condition. If for some reason a part doesn't work I will offer a full refund. Okay here's the list:
  • Left and Right gas struts for boot $15
  • Series 1 Ignition module $20
  • Power Steer Fluid resevoir cap $5
  • AAC Valve Assembly $30
  • Rear wiper arm with wiper blade $10
  • 6 Factory Coil Packs $100
  • Rb25 AFM (series 1 green label) $25
  • Throttle Body $25
  • TPS (Auto) $25
  • 2 Stock bov's $20 each
  • Crank angle sensor $30
  • Coil pack loom $25
  • 2 Main Auto Ecu's $30 each
  • Stock plenum $50
  • Key ignition surround $2
  • Coin holder for dash $2
  • Center air vents $5
  • Interior clock assembly $5
  • Front and rear passenger door scuff plates $5 each
  • Interior rear view mirror assembly $10
  • Hose from AAC valve to crossover pipe $5
  • Auto ECU (small one on drivers side) $25
  • Boot lock assembly $10
  • Interior passenger sun visor with mirror $10
  • Interior plastic mould cover for main ecu $5
  • S13 clear indicators for front bumper. Brand new never been used. These fit perfectly in my aftermarket front bumper bar. I think it was a 'type 4' bumper from vivagarage.com $30
  • Approximately half a litre of castrol transmax Z. I really don't wanna go throwing this stuff out as its so damn expensive. The best fluid you can get for the auto transmission and retails for about $80/4 litres. Less than 6 months old. $5
  • Exide Endurance battery (310 CCA) just under 2 years old $15
  • Metal elbow pipe from turbo to intercooler piping $5
  • Snorkel bit from stock air box $5
  • Pod enclosure for highmount turbo setup $25
  • HKB aftermarket steering wheel boss kit $15
  • Complete Boot fuse box assembly $20
  • Nissan coilpack cover twin cam 24 valve 2500 $20
  • eyelids for series 1 headlights (black) $10
Feel free to give me a call on 0433373183 rather than sending a PM as I only check my inbox once a day.
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
