Hey all! Selling a few parts off my smashed skyline. It was a r33 gts-t, series 1, 4 door (automatic). I haven't got any pictures as of yet but if pictures are required feel free to ask. Everything is in great working condition. If for some reason a part doesn't work I will offer a full refund. Okay here's the list:
  • Left and Right gas struts for boot $15
  • Series 1 Ignition module $20
  • Power Steer Fluid resevoir cap $5
  • AAC Valve Assembly $30
  • Rear wiper arm with wiper blade $10
  • 6 Factory Coil Packs $100
  • Rb25 AFM (series 1 green label) $25
  • Throttle Body $25
  • TPS (Auto) $25
  • 2 Stock bov's $20 each
  • Crank angle sensor $30
  • Coil pack loom $25
  • 2 Main Auto Ecu's $30 each
  • Stock plenum $50
  • Key ignition surround $2
  • Coin holder for dash $2
  • Center air vents $5
  • Interior clock assembly $5
  • Front and rear passenger door scuff plates $5 each
  • Interior rear view mirror assembly $10
  • Hose from AAC valve to crossover pipe $5
  • Auto ECU (small one on drivers side) $25
  • Boot lock assembly $10
  • Interior passenger sun visor with mirror $10
  • Interior plastic mould cover for main ecu $5
  • S13 clear indicators for front bumper. Brand new never been used. These fit perfectly in my aftermarket front bumper bar. I think it was a 'type 4' bumper from vivagarage.com $30
  • Approximately half a litre of castrol transmax Z. I really don't wanna go throwing this stuff out as its so damn expensive. The best fluid you can get for the auto transmission and retails for about $80/4 litres. Less than 6 months old. $5
  • Exide Endurance battery (310 CCA) just under 2 years old $15
  • Metal elbow pipe from turbo to intercooler piping $5
  • Snorkel bit from stock air box $5
  • Pod enclosure for highmount turbo setup $25
  • HKB aftermarket steering wheel boss kit $15
  • Complete Boot fuse box assembly $20
  • Nissan coilpack cover twin cam 24 valve 2500 $20
  • eyelids for series 1 headlights (black) $10
Feel free to give me a call on 0433373183 rather than sending a PM as I only check my inbox once a day.
  • Replies 45
  • Throttle Body $25
  • TPS (Auto) $25
  • Stock plenum $50
TPS (auto): sold!
Series 1 ignition module: sold!
AAC Valve assembly: sold!
Crank angle sensor: sold!
Coilpack loom: sold!
Nissan coilpack cover: sold!
hay mate chasing the drivers door plastic with the electronics on it ne chance you still have that????
I have the switch surround and switches if he cant help, both out of a series 1
Sorry man but the drivers door was mashed up pretty good. nothing was intact
TPS (auto): sold!
Pod enclosure: sold!
Snorkel from stock airbox: sold!
Just thought I'd add that the steering wheel boss kit I have for sale is actually for hicas as someone on the forums pointed out to me. I also have a few other things that I'm selling as well
  • Climate control unit $10 (i honestly couldn't say if this still works or not. The unit is still intact apart from the clip on the left side which is snapped off but isn't a big thing. Obviously, if it doesn't work I won't charge for it.)
  • TPS (Auto) $20
  • Hicas ECU $15
  • Stock Fuel Pump assembly $20 (was only replaced to make way for a tomei fuel pump)
  • Stock gear knob $10 (manual)
All the other items listed are still for sale.
  • Throttle Body $25
  • TPS (Auto) $25
  • Stock plenum $50
Stock plenum: Sold!
Main auto ecu: Sold! (I still have another one available)
I also have a bonnet lining for sale as well with all the clips. There are a few cuts on the lining due to being involved in an accident but is still usable: $5
If pictures are required feel free to ask.
  • 3 weeks later...
  • 3 weeks later...
still got the stock bov??? need one pls
yea man I still have 2 stock bov's. $20 each. your welcome to come around this arvo if you wish. my number is 0433 373 183
hey mate you got the 90 degree rocker cover fitting
Nah sorry I don't
  • 4 weeks later...
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
