Hi - chasing the steel automatic gearbox fluid return lines? Hoping you may have them. Denis 0403829350
Sorry man they were sold along with the wreck.
  • Replies 45
Hey mate chasing the plastic around the steering colum and the main plastic bit on the dash and the armrest handle on the passenger ???
Sorry man don't have those parts.
Can you put up a photo of the pod enclosure?
Already sold!
  • 3 weeks later...
Price drop!!!
Climate control unit $5 (i honestly couldn't say if this still works or not. The unit is still intact apart from the clip on the left side which is snapped off but isn't a big thing. Obviously, if it doesn't work I won't charge for it.)<LI>TPS (Auto) $10<LI>Hicas ECU $10<LI>Stock Fuel Pump assembly $10 (was only replaced to make way for a tomei fuel pump)
<LI>Left and Right gas struts for boot $10<LI>Power Steer Fluid resevoir cap $5<LI>Rear wiper arm with wiper blade $5<LI>6 Factory Coil Packs $50<LI>Rb25 AFM (series 1 green label) $15<LI>Stock bov $15<LI>2 Main Auto Ecu's $15 each<LI>Key ignition surround $2<LI>Coin holder for dash $2<LI>Center air vents $5<LI>Interior clock assembly $5<LI>Front and rear passenger door scuff plates $5 for both<LI>Interior rear view mirror assembly $5<LI>Auto ECU (small one on drivers side) $15<LI>Boot lock assembly $5<LI>Interior passenger sun visor with mirror $5<LI>Interior plastic mould cover for main ecu $5<LI>S13 clear indicators for front bumper. Brand new never been used. These fit perfectly in my aftermarket front bumper bar. I think it was a 'type 4' bumper from vivagarage.com $15<LI>Exide Endurance battery (310 CCA) just under 2 years old $5<LI>HKB aftermarket steering wheel boss kit (hicas) $10<LI>Complete Boot fuse box assembly $10<LI>eyelids for series 1 headlights (black) $5
Hey mate ... do you still have the auto ecu for sale?
Yea man I still have it. were u after the main ecu or the smaller ecu located in the driver kick panel? I still have both available.
I need a main ecu to suit an auto r33 s2. Mine is not receiving the signal properly from the coolant temp sensor and leaning out on boost.
Is yours series 1 or 2? i dunno if theres any difference
hey. mines a series 1 so u might wanna check and see if there interchangeable as I'm not too sure if they are
hicas ecu: sold!
ok here's a list of what's left guys and please don't ask me for other parts because this is all I have left!
  • Climate control unit $5 (i honestly couldn't say if this still works or not. The unit is still intact apart from the clip on the left side which is snapped off but isn't a big thing. Obviously, if it doesn't work I won't charge for it.)
  • Stock fuel pump $10 (was only replaced to make way for a tomei fuel pump)
  • Left and Right gas struts for boot $10
  • Power Steer Fluid resevoir cap $5
  • Rear wiper arm $5
  • 6 Factory coil packs $50 (had no problems with these. only removed for an upgrade)
  • RB25 AFM (series 1 green label) $15
  • Stock bov $15
  • 2 main auto ecu's $15 each
  • Center air vents $5
  • Interior clock assembly $5
  • Front and rear passenger door scuff plates (off a 4 door) $5 for both
  • Interior rear view mirror assembly $5
  • Auto ecu (small ecu on drivers side) $10
  • Boot lock assembly $5
  • Interior passenger sun visor with mirror $5
  • Interior plastic mould cover for main ecu $5
  • S13 clear indicators for front bumper. Brand new never been used. These fit perfectly in my aftermarket front bumper bar. I think it was a 'type 4' bumper from vivagarage.com $15
  • HKB aftermarket steering wheel boss kit (hicas) $10
  • Complete Boot fuse box assembly $10
  • eyelids for series 1 headlights (black) $5
If any pictures are required don't hestitate to ask.
ill grab the eye lids dude. chasing various rubber hoses from engine. Would you em?
Hey yea i still have the eyelids. And i have a few random hoses lying around so your welcome to have a look. Did you wanna organise a time for tomorrow? feel free to sms me on 0433 373 183 and i'll give u my addy
  • 1 month later...
bump!
  • Climate control unit $5 (i honestly couldn't say if this still works or not. The unit is still intact apart from the clip on the left side which is snapped off but isn't a big thing.)
  • Rear wiper arm $5
  • RB25 AFM (series 1 green label) $10
  • Stock bov $10
oh,i can pcikup the eyelids tomorow if you like,, and maby some other stuff. centre vents if they work.. mine get stuck and some pparts are broke :(... im aftter the long cover that goes under the steering wheel.. the fuse cover is on it as well. . i need the clips and all. mine are broke :/
oh,i can pcikup the eyelids tomorow if you like,, and maby some other stuff. centre vents if they work.. mine get stuck and some pparts are broke :) ... im aftter the long cover that goes under the steering wheel.. the fuse cover is on it as well. . i need the clips and all. mine are broke :D
Sorry mate i have another buyer for the eyelids. center vents are yours! they work fine and are in good condition. I don't have the long cover that goes underneath the steering wheel or any of the clips, sorry.
