Hey all
cant run my rb26 atm, need it ready in a days time for a tune session.
Ive shagged the 2x stock gtr afm's. Ruined.
I have here 2 x Q45 air flow metres
these are 3-pin compared to the gtr stock 4-pin
B-D-E are the markings, I believe it is Signal (B), Ground (D), Power (E)
the stock gtr afms have Signal, 12v ground, Signal ground, Power
How do I wire this up?
Everything Ive tried doesnt work.
ie, incorrect wiring means it wont turn over.
Ive done it as it should be, Signal, 2x ground wired together, Power, however the car starts, idles for 2secs then stops.
Wont run for more than 2 seconds.
When I had the wiring up to the stocker afm's it was fine, however Ive ruined the pin connectors, tried to repair, and f**ked it all up.
How do I wire the 4-wire into the 3-pin Q45 afm?
suggestions please (man my soldering skills are f**ked up!)
https://www.sau.com.au/forums/topic/315295-help-needed-q45-afm-wiring/
I guess it wont work because the power-fc doesnt have settings for Q45 under airflow
* R32bnr
* R33bnr
* Apexi super suction
* RB25
* VG30
are the only airflow setting options.
going to have to rebuy stocker afm's . . . . . grrrr
Is it easy to reflash the firmware on r32/r33 gtr power-fc's?
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
