I was over at a mates place this week and we were just having a look around his shed.....(where my motor is being stored atm)....and his son has had some mates around so they have taken the cover off...and wasps have built some pretty little mud castles in the intake ports.....(motor has no manifolds on it)
What can i do...
Head off job? or....
(deep sigh)
https://www.sau.com.au/forums/topic/315310-wasp-nests-ino/
Turnthe engine on its side on an engine stand, one cylinder at a time turn engine until cylinder is in compression stroke (vavles closed) break away nests, air blower, hope for the best.
One of those fibre optic cameras would handy be handy aswel
Edited by aleks
https://www.sau.com.au/forums/topic/315310-wasp-nests-ino/#findComment-5165491
Leave wasps alone. They get very narky when you disturb their nest or spray insect spray in their general direction - particularly European wasps. Unlike bees, they can sting multiple times (they don't lose their stinger).
https://www.sau.com.au/forums/topic/315310-wasp-nests-ino/#findComment-5165499
If they have gone up the exhaust they may have nested inside the cylinder, the one with the valve open. I worked on a pump motor from a farm with wasps nesting like this and it wasn't worth rebuilding. The clay gets into everything, little buggers.
Definitely need to pull the head off.
https://www.sau.com.au/forums/topic/315310-wasp-nests-ino/#findComment-5165767
Ok i went to the head shop today (super flow heads), I was told if i can give it to him with no cams in it. Then to have it acid dipped, new seals, and machined, would cost me between 300-400 dollars.
Does this seem about right?
So this leads me to this, would i have much problems pulling out the cams, and then re installing them again (or maybe aftermarket 256's or something...).
I can get a genuine nissan vrs kit, for approx. $380, so i would provide the seals, (this should bring the cost down a tad).
And would i really need to machining?
I have no idea tbh when it comes to doing any work on the heads this will be the first time i've taken one off and put it back on myself so yeah...dun wanna mess it up..
Cheers
https://www.sau.com.au/forums/topic/315310-wasp-nests-ino/#findComment-5166809
Price sounds good.
And the valve stem seals are worth nothing really, so won't be a huge saving there.
I payed $550 for mine with a crack and pressure test.
The machine they normally do is just a tidy up (skim the surface and enough to make sure valves seal properly)
https://www.sau.com.au/forums/topic/315310-wasp-nests-ino/#findComment-5166883
May as well keep it all in this thread, down the track the motor will probably have between 15-18psi getting pushed around it, would you guys reccomend using a metal head gasket? I had a quick look around the site, and from what i can tell the cometic head gaskets and the such wont sell properly unless i have both surfaces perfectly true...would this be the case if i wanted to run any sort of metal gasket, so machining would be in order for both the head and block?
https://www.sau.com.au/forums/topic/315310-wasp-nests-ino/#findComment-5167119
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
    • If it's been tuned idle rpm can be changed.
    • Very slightly as there are bars connecting both sides of the ramp. The only difficulty that I had was doing the gearbox, everything else so far has been ok
