A well known auction site is selling what appears to be a new age version of the CONSULT described in the original GTR workshop manuals. It basically includes the cable that hooks up to the connector in the fuse box and connects to software on your laptop via USB. Just wondering if anyone has purchased one of these and found it to useful or a dud.
http://cgi.ebay.com.au/OBD-datacable-consu...a#ht_7276wt_939
The figures displayed in one of the software screen shots were clearly bogus but it's hard to tell..
https://www.sau.com.au/forums/topic/315384-obd-datacable-consult/
Hi Johnspec,
I don't know about the exact cable being sold on eBay but it looks very similar to one I bought for a friend recently.
These guys are based in Adelaide and make a USB cable that plugs into the Consult interface: http://www.plmsdevelopments.com/consult_if.shtml
The list of supported vehicles is available here: http://www.plmsdevelopments.com/consult_vehicles.htm
My mate has a late 90s Maxima and used the PLMS cable successfully to detect a knock sensor fault. Whether it's suitable for proper tuning work I have no idea.
Cheers
Hey, I've used a Nissan version of the Consult cable but its only limited to the software you've got. With the basic software they provide or that you can download, you'll only be able to detect errors and check up on engine vitals. You'll need to purchase the full software if you want to be able to tune your car. Check out NIstune videos on youtube as they demonstrate how to do basic tuning using their software.
Hope that helped :D
its not the 'ebay' thats selling them, but a seller on ebay, in this case in latvia (read into the location what you will)
similar cable to the ecutalk/plms (aus) or blazt (nz) cables - they all work with same software etc.
dont think its a 'new age' version of consult or anything like that, definitely cant compare them with the nissan consult unit itself, <$100 isnt going to do half of what a $5000 piece of equipment will do, but it does most of what you need - the sensor readings and fault codes. has saved many people a trip to mechanics (often costs more than the cable) if theyve been able to see a certain sensor is dead or a fault code has been triggered etc. found many a dead o2 sensor which costs people lots of $ in lost fuel economy.
the cables shouldn't be duds, but for another $2.01 ($75) it might be worth getting an ecutalk one, or a bit more for plms/blazt. the obd scantech + ecutalk combo is more than adequate for majority of people, i wouldnt spend extra $ on any paid software unless you know you need it
+1 for ecutalk cable. i have a USB one which i bought from a certain member on the pulsar forums who is also on this forum (didn't know they were on this forum until after i had bought it, but makes no difference). you know who you are, LOL
I've got a serial cable from PLMS and a license for Nissan Datascan, ran it on my carpc full time and it was invaluable with the sensor/fault readouts and the datalogging.
Me too. Get a cable and register for datascan from plms. You then know your cable is guaranteed to work and have technical backup with the software. With the cheap chinese knock offs, its a bit hit and miss with the cable.
And newkleer knows his stuff on this gear too. He has been pro active for quite a while on this gear.
Edited by Lippo
+1 ecutalk is worth every cent :D
I've installed permanently in my car.
  • 5 weeks later...
Hey guys, just wondering with these consult cables etc does it work with an aftermarket ecu, will this still be able to read the fault codes etc? i have a Vipec installed. i am yet to get vipec software onto laptop to actually have a look at it myself, it might already be able to read all sensors etc and stock fault codes, im not sure.
Im looking at buying one but if it wont work with aftermarkket ecu then not much point is there.
Thanks
Daz
Thanks
Daz
Full aftermarket systems (ECU) - NO
Some piggyback ECU - Sometimes
Stock ECU - Yes
generally remaps, nistune, daughterboards, and piggyback systems all retain consult. sometimes the readings wont be accurate if you're intercepting signal (SAFC etc) and so on.
but replace the nissan ecu with another one (power fc, haltech, ems, etc) and no it wont work.
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
