Wouldn't normally create a thread on defects because it's a shithouse topic, but I'm curious as to how many people from here (if any) got pulled over yesterday for inspection. Seems to me they were having a blitz around the Wantirna area because a mate got done yesterday by the same Knox TMU car that got me earlier in the day. And no, it wasn't Pettett.
Also saw a few modified cars pulled over yesterday on the way home from dinner lastnight, bonnets popped.
https://www.sau.com.au/forums/topic/315469-who-got-defected-yesterday/
  • Replies 53
I drove through Knox yesterday (and nearly every other day for the past 5 months) and still had no hassles.
The only time I've ever had a run in with police in that area was when I was parked at a school at night (looked suspicious) and they realised that I was driving manual on an auto license.
I guess I'm just lucky.
A couple of my mates got done over the weekend, I knew this was going to happen so my car stayed locked in the garage.
So much for the big crackdown on drink drivers over the easter break...trust the coppers to grab anything they can. Rats.
Left the GTR parked in the garage over Easter. Figured it would be safer given the bad press imports get.... especially over the break.
yeh spot on few ppl i know got done so took the oppertunity to fix some niggly litte shit like loose mesh on the front bar losl sucks though cos weather was perfect for cruising yesterday .. :D
yeah i seen alot more TMU out lately in my area.. (knox) and yes i have seen pettitt almost everyday. constantly pulling someone over. (mostly on stud rd)
seen more than enough cars pulled over by undercovers. even saw a au falcon wagon undercover pull over a car yesterday
AU Falcon?
I thought they would be a little old for the police by now?
I got pulled over on monday. I bought the car 2 weeks ago with a roady and still copped a fine for 300 buck for drivin a unroadworthy vehicle.
Only reason I didn't get defected is cos I was on my way to the airport and was in a rush.
It was a RBT on Kellets rd near stud. There was a couple of skylines there getting done too.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
