Wouldn't normally create a thread on defects because it's a shithouse topic, but I'm curious as to how many people from here (if any) got pulled over yesterday for inspection. Seems to me they were having a blitz around the Wantirna area because a mate got done yesterday by the same Knox TMU car that got me earlier in the day. And no, it wasn't Pettett.
Also saw a few modified cars pulled over yesterday on the way home from dinner lastnight, bonnets popped.
https://www.sau.com.au/forums/topic/315469-who-got-defected-yesterday/
  • Replies 53
I drove through Knox yesterday (and nearly every other day for the past 5 months) and still had no hassles.
The only time I've ever had a run in with police in that area was when I was parked at a school at night (looked suspicious) and they realised that I was driving manual on an auto license.
I guess I'm just lucky.
A couple of my mates got done over the weekend, I knew this was going to happen so my car stayed locked in the garage.
So much for the big crackdown on drink drivers over the easter break...trust the coppers to grab anything they can. Rats.
Left the GTR parked in the garage over Easter. Figured it would be safer given the bad press imports get.... especially over the break.
yeh spot on few ppl i know got done so took the oppertunity to fix some niggly litte shit like loose mesh on the front bar losl sucks though cos weather was perfect for cruising yesterday .. :D
yeah i seen alot more TMU out lately in my area.. (knox) and yes i have seen pettitt almost everyday. constantly pulling someone over. (mostly on stud rd)
seen more than enough cars pulled over by undercovers. even saw a au falcon wagon undercover pull over a car yesterday
AU Falcon?
I thought they would be a little old for the police by now?
I got pulled over on monday. I bought the car 2 weeks ago with a roady and still copped a fine for 300 buck for drivin a unroadworthy vehicle.
Only reason I didn't get defected is cos I was on my way to the airport and was in a rush.
It was a RBT on Kellets rd near stud. There was a couple of skylines there getting done too.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
