  • Replies 59
Posted Images
Hey guys I'm having trouble moving my car so I'm considering parting it out if I can get some offers on the bigger parts all parts have minimal use and were purchased around 12 months ago and have around 6 hours dyno time, <250kms road use and 1 powercruise weekend on them
If you're after more info send me a PM for pics check the car for sale thread here http://www.skylinesaustralia.com/forums/19...20-t311269.html
Parts
Garrett GT3071r .84ar T3 flanged with 38mm turbosmart gate welded on to the rear housing price for both 1300
turbo on its own 1100
gate on its own 300
Braided oil and water lines to suit this turbo 250
Dump pipe to suit this turbo high mount to cat 200
ETM exhaust manifold suit RB i asked leigh from ETM and he told me this will fit a R33 with rb also it is T3 flanged 850
Haltech E11V2 boost control unit and haltech dual stage warning and shift light 1500
plug in loom suit RB 150
ATS twin plate carbon clutch 250mm 1200
D2 Adjustable coilovers suit S13 800
Davies Craig 115l Electric water pump 150
440cc injectors 300
JJR Coilpacks 250
Z32 front calipers and discs drilled for 4 stud minimum 16inch wheels 450
Alloy Radiator sut RB or CA designed for S13 200
Standard RB injectors 100
Dump pipe to suit RB in S13 standard turbo 150
Standard RB20 ECU 150
Standard AFM green label with pod adapter 50
Standard RB 20 turbo manifold 150
RB20 5 Speed good condition sstill shifting smooth no clutch 600
Tailshaft to suit RB20 box in s13 200
Front mount 100
Piping to suit rb in s13 to suit forward facing plenum 100
Forward facing plenum no cold start to suit RB 200
Custom catch can welded on to intake pipe wich has speedflow lines to be plumbed back in to turbo oil drain k and n filter 150
k and n filter 3 inch inlet 50
3inch catback suit s13 canon muffler 150
Autometer 25/8 gauge oil pressure(mech), Water temp(elec) , Volts (elec) 60ea
Gaauge cups suit above gauges 20ea
Set of 180SX standard wheels 100
Plenty of other parts available just ask if i can get some intrest in some of the parts i will strip all parts located in wollongong NSw around 1 hour south of sydney and i work in campbelltown so pickup available there also pm me with interest and we will take it from there. prices are negotiable however so stupid offers thanks as you will be ignored
Thanks
Hey and i see some more pics of the turbo manifold.. [email protected]
Bump
Still got
GTR injectors
RB20 engine
RB20 5 speed
ATS twin plate clutch
catch can
braided lines suit high mount gt series garrett
Mate are the GTR injectors still up? Good condition?
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
