Nah they dont look like that ^ and they say Xenon but you cant see it in this pic.
I have only ever had Cut H7s in it, and thats what was in it when I purchased the car.
Trimmed H7's is what I used when I did a dodgy conversion job to pass Regency (as I run D2R xenons - that's what came with the car when I bought it - freshly complied).
(Side note: I'm sure I already replied to this earlier with pretty much above - but my post seems to have gone missing...)
https://www.sau.com.au/forums/topic/315534-r34-headlamps/#findComment-5167411
This is what I have been using.
Dont H1s have a different plug thing?
I want to buy some new bulbs tonight hopefully. Just not sure what to ask for.... do the D2R lights come in all different sizes or do I just say D2R?..
https://www.sau.com.au/forums/topic/315534-r34-headlamps/#findComment-5169957
D2R xenons are very expensive over the counter; You could be talking $200-300 for a pair, easy. Getting them online is a lot cheaper.
However - this assumes you still have the xenon ballast, cabling, plugs, etc to hook it all up to.
A D2R bulb looks like this:
... totally different plug to what you have now. But the base (with trimming), and the light source of the bulb is about the same as a H7 bulb (which is why they're sometimes used for compliance purposes, I believe).
https://www.sau.com.au/forums/topic/315534-r34-headlamps/#findComment-5170021
Ill have to check if I still have all the stuff to plug them into. Not sure I do... will check tonight.
Might have to do the trimmed H7s again for now! I hate driving with one headlight. Make my car look pov. Hahaha
https://www.sau.com.au/forums/topic/315534-r34-headlamps/#findComment-5170163
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
