Just wondered what times the quickest Stageas in oz/nz/japan were running .
Does anyone have any confirmed run times
does anyone know what the standard quarter mile is for a standard series 1 and 2??
sorry chucking another question in your post
I ran an 11.7 also in mine.
<this one. 500rwhp. There is a youtube of it running a 12.2 somewhere but wasnt running high boost. The car is in WA now so I hope the new owner (yes you Zane) takes it to the track in the middle of winter. My run was on a shit Darwin track at around 30deg.
  • 3 weeks later...
11.3 at 124.8mph mine did with 560rwhp and full weight (1740kg + driver) with 235/17 street tyres, Engine had made over 600hp previous but had spark issues so only ran on 18psi boost setting.
It will be featured in HPI magazine very very soon (next 2-3 months)
very nice !!!have any pic's?
thanks guys, the photoshoot for the mag was done ages ago so it has 33 gtr rims in the mag, maybe one pic of the LM's on it, the car now runs a totally different setup and that engine and box is in a 32 gtr. Should be interesting with the weight saving on what its capable of.
heres the actual pics of the drag run... (the other car ran a 10.6 and check out the KMH speed difference, i caught him in the top end, though he was auto and had a killer launch)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
