Im going to be upgrading my ruined standard shocks + kingsprings (worse combination ever, aweful compared to standard)
Now I was considering getting the bilstein sydney kid recommends in his old group buy along with springs and the sway bars, or I was considering tein super street coilovers with 225lb (4kg) springs all around.
What setup is going to be better for a daily driven R32 skyline that will see the track every few months.
It has some serious power ~240rwkw so I need something that will squat a little and hookup but also that isn't sloppy like the standard springs nor so stiff the rear end just skates all over the road.
What setup do you guys think will handle better for my situation? I am looking at spending around the $1000 mark and not much more, both of these kits are around this price, the teins being about $900 and the bilstein combo roughly $1200.
Thanks in advance. = )
Teins are soooo silky for daily driving, a necessity for daily driving on crappy Sydney roads... I am yet to use them on any track, so have them on the softest setting and they are without exageration smoother on the road than my mates M3. Probably not the best for handling, but that might change with the harder settings.
They don't lower that much either if that is a priority.
I have also had HKS Pro Performer which are smooth, handle well, but unreliable, and GReddy Type S - awesome compromise!
Not sure how you going to get a bilstein setup for $1k
I got mine from ERD which is around the $1400 mark. Same setup as sydneykid's (but progressive kingsprings instead of linear whiteline springs)
http://erd.com.au/index.php?option=com_seb...=store&ck=2
Email ERD and ask them what would suit you.
Yeah bilstein setup is looking more like $1400 for the lot including camber kit, sway bars etc however after talking to a few people I am convinced it is the better setup.
I am going to go for a drive in a car with the sydneykid setup in it and compare it to my mates teins. It is a daily driver so I would prefer a soft setup with rollbars to counter the roll instead of stiff springs.
you are better off with the bilstein setup. Its designed for australian roads and its nice to drive on roads. Once you load up the springs by pushing the car, the springs stiffen up and you get some awesome handling.
In the end, shocks/springs only make up one bit of the suspension. Swaybars do a lot in terms of handling.
Mine arnt......I would definatly go the bilsteins over the tiens any day.
the high speed damping in the Tiens is crap...way to crashy over cats eyes etc and they are too soft in the front spring rate for track work imo.
btw this is for a 33 gtst
I havent driven a 32 with them so I cant comment on that
I've got Gary's bilsteins in both my stagea and 32 gtr race car. Excellent mono shock damper, way better than anything else in the up to 1500 price range. Obviously there are better shocks again in the $4k+ range.
Hey boys. Went for a spin in an R32 with the sydney kid setup tonight, was a very very nice ride, surprised by how soft and cruisy it felt over bumps and on the street. The turn in and handling was very impressive as well, would have to say it definitely rivals the teins and with a better ride.
Now I have run into an issue, the part numbers for the bilstein shocks and the dampening rates are not to be found anywhere in the old group buy thread, and it appears sydney kid is no longer active on these forums. Would anyone here know these values or where I could find them out? Same goes for the spring rates etc, I can most likely get these fairly quickly but if I have anyone here to double check them with that would be tops.
Would very much appreciate it.
Cheers guys :laugh:
  • 4 years later...
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
