Plazmaman all the way. i have one on my 25. workmanship is beyond belief!
guys are fantastic to deal with and very helpful.
standard throttle body bolts straight on if thats the one you want.
more room in the engine bay because of this...easier to fabricate the cooler piping.
its just better so buy it...and its WAY cheaper than original greddy. its about $1000, greddy is like $1700...
oh and copies of the greddy are just a waste of time...
Weve run both on our race car with identical setups as a back to back comp. Done at mercury a good 2-3 years ago now. We picked up a good couple hundred rpm in the midrange and more power with not much change in the top end. Currently run the plasmaman plenum, though I do have a greddy on my raod car.
dont underestimate the greddy. I have egt sensors in my exhaust manifold and the tuner was very impressed with the evenness of the temperatures across the cylinder range. That tells me I am getting a good even fuel distribution across all 6 pots.
This is in no way a slight at the Plazmaman product, it may well do the same but i aint changing to find out.
No one is doubting the even-ness in flow of either product, hell that is why I have a HYPERTUNE plenum on my r34 gtr. The engineering and design of there (hypertune) plenum's mean there is only a 0.5% difference from the highest to the lowest runner. (I can't remember exactly where that number came from, but I am pretty sure the lad's at Hypertune told me that when I was looking at my options).
The single biggest factor when deciding between these 2 plenums (plazmaman and Greddy) is the loss of midrange torque due to the short runner on the Greddy, and the second is SPACE. The Plazmaman sits up higher the whole way along and as such becomes unsuitable for some installations (such as RB25's into s13's, rb20's into old school Capri's etc). Sometimes it is a little more headache with the Plazmaman because of this, but we try every possible solution before throwing on a Greddy. We have even used R33 runners/PM tops on R34 engines as they sit in different locations (we did this on the VC commodore with NEO RB25 conversion).
The loss of midrange is an easy fix, I have istalled a 40 mil plenum spacer made by mace engineering to add runner length. it also has the added advantage of reducing intake temp.
With the engine running hard on track i can put my hand on the plenum. A couple of minutes of heat soak after the engine is switched off tho and its too hot to touch,
Both obviously good products, use what you prefer.
OK slightly off topic...but onthe topic of the Hypertune plenum.....Trent have you done any back to back testing of the Hypertune vs stock on the black top SR's?
Unfortunately not. We used to do plenty of SR20 work a few years ago, but since that time the large majority has been RB's and 2J's. We still do SR's but not to the same extent or quantity that we used to. Hypertune introduced their plenum after this time, so I haven't really had a customer request to do it, so we haven't. I really want to build a street/drag car to take out the under 2.4L radial record, but am a bit preoccupied with the workshop and our r34. If I find the right client and he wants to test this sort of stuff, then yes I would love to see how they compare. I dare say it would be a similar situation in that the shorter runners creates less torque in the mid range, later spool, but good outright power.
any one done a plazmaman plenum into a neo rb25
and what about one in a r32
Its something that you will have to try in your engine bay because it in a different engine bay, but there should be a combination of runners and tops that will work with your car. We fitted a neo 25 into a VC commodore and we ran into problems with the large brake booster taking up a big chunk of area near the firewall/plenum. What we noticed was that the r34 runners extend further away from the engine and the plenum sat further away to suit so that it was fouling on the booster. Luckily we had another gtst in the workshop with a plazmaman setup on it, so we test fitted that and it turned out it was about 10-15mm closer to the engine and it was just enough to clear the booster. So we bought a second hand set of r33 runners and swaped the r34 plenum with an r33 one from Plazmaman. It took lots longer to install, but there was a solution.
Do you have any pics of the 40mm phenolic spacer?
Cheers
Justin
Have you done back to back on a gtr the hypetune rb26 plenum vs stock gtr one?
What the difference?
Edited by sky30
I just installed my plazmaman pro series kit, I know your asking for a vs greddy plenum but I had stock plenum with a greddy retun flow cooler. After the install I gained maybe 10rwkw, but added a shit load more response. As I'm running a gt3076 it was slighty laggy with old setup but now I've seen a 500rpm+ boost pick up. And +1 on the workmanship!!! Being the proseries kit I got also got the billet thottle body, and pre fab'd piping, I found it was easier relocating battery to the boot.. Maybe something you don't need to do with greddy??? And let's not forget plazmaman is very exy!!
God those throttles are gorgeous, gotta get around to getting one, would finish mine off nicely me thinks. I see that they have slighlty changed the plenum with "Plazmaman" not being engraved on the top but now on the bottom.
Edited by PM-R33
  • Like 1
Cheers
Justin
I'd like to see these aswel, esspecially if the stock rb26 plenum can accomodate them (I'd guess it's a simple fit and some basic pipework), more torque is always welcome here :P
Just to confirm , did someone mention you can use the std R33 throttle cable with this plenum ?
Also one for Mercury , I don't suppose its possible to use the GTt runners and PM plenum on an R33 ?
Would there be any gain or just lots of grief for no real purpose .
Lastly , WHAT is the size of the R33 std throttle plate ? PM site shows a 66mm throttlebody as their smallest offering so whats the difference between this and the std R33 25DET throttle plate size ?
Cheers Adrian .
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
