Are there any disadvantages to running a 80mm throttle body on a greddy manifold on a rb25 if your "only" making about 250rwkws?
Disadvantage would be light throttle modulation would be some what crappy.
  • 5 months later...
  • 2 months later...
hey all,
i have my plazmaman etc on my r32 rb25.
now i cant for the life of my find injectors + rail to fit under it.
i run e85 and ~350rwkw
im running stock hiflowed injectors.
now i wanna get rid of these for top feed ~1000cc but cant find any.
i have come to the conclusion that changing to a greddy is prolly the best option.
unless anyone out there has found injectors to fit?
if i did change to greddy do stock rail + injectors fit?
hey all,
the short id 1000 dont clear?
my car has a plazmaman plennum on it making 470rwhp and the midrange response feels so much better than when I had a greddy plannum, unfortunately I don't like the look of plazmaman plennums. Want to chage but I'll put up with the uglyness for better response and mid range.
I use a genuine Greddy coupled to a 30 mil phonelic spacer. The added runner length fixes up the low midrange and purely from a looks point of view the greddy shits all over the plazmaman.
The tuner also commented on how even my cylinder temperatures were as well. Even distribution will do that.
didnt know the id1000 came as a shorter unit?
what rail do they take, as i found the rail is the thing that fouls.
and yeh im gutted if i have to loose response etc, but my fuel system is pushing it.
Anyone else running plazmaman plenum bothered to pull their plugs and see if they are or not even
Also, anyone running anything other then the plasmaman throttle or std throttle body?
running a CPC plenum and all my plugs are the same when i removed them.
would be keen to see a dyno comparison with stock vs FFP.
if anyone wants to give me a r34 gtt neo standard plenum ill gladly test :D
I can lend you one.
Clean out your Pm box. I can't Pm you
Pretty agricultural those things are they cheap?
anyone know if these injectors would fine?
cant find top feeds to fit under my plenum.
http://www.ebay.com....47#ht_751wt_907
or
http://www.ebay.com....5#ht_1162wt_907
saves me having to change plenum...
highflows.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
