Taken from their facebook page: http://www.facebook....229267523757328
got the same thing here for under 100, use alot of them too when we fit id1000cc http://goodiesdirect...&product_id=405
  • 1 month later...
wish i knew before about this F*kn manifold..
someone must have run top feeds with a plazmaman..
I am having the same issue fitting id1000's and the plazmaman top feed rail. Did you get an early version of the plenum? I did, and i have had all sorts of trouble with top feed fitment, however they have since changed the design and it should clear up the issues your having. Give them a call, im sure they will be happy to fix it up for ya.
Can some one post a pic of there id2000 install into an rb manifold. Need to lnow what rubbers or oring u have used where the injector seals into the port.
From memory I bought two sets of seals from autobahn. Picked out the right sizes and it was all good.
  • 1 year later...
a bit of a thread dig sorry guys,
trent, does these takashi fuel rails you have used in the past, do these clear the plazmaman plenum when using 11mm 1000cc injector dynamics? and when you do use them are you using id1000's with no top hat installed?
TFR-6584%20Fuel%20Rail%20Nissan%20ECR33-
I am using a HKS rail with full height 2000cc injectors and plazmaman rail... Pics in my build thread in Sig if you can find them!
hmmm i wonder if yours being a neo rb25 would be any different. i actually wouldnt have thought that full height injectors would have fitted up all ok. is the hks also an 11mm rail?
Trent if you do see this please let me know!
cheers
cheers
I dont think it would be any different in terms of height.
And yes, it is an 11mm rail. There are plenty that have done it.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
