Are U Stripping Your R32 Gtst But Can't Be Bothered Pulling Everything Apart? I Can Help
Last time the car was on a hoist the mechanic noticed that the rear right subframe bush was leaking, there are marks on the body where its been hitting, & rear end is very squirmy under accelerating if i'm not getting severe axle tramp.
Basically because I don't want to have the car off the road during the week, i have figured it may be easier to swap the whole subframe or rear end myself opposed to paying a mechanic all the labour involved dropping the rear end and pressing out all the bushes & replacing.
I am located in melbourne, i can organise pickup wherever/whenever suits.
i am after either a subframe with the bushes in reasonable condition or whole rear end with or without diff. My car has ABS so the diff is slightly longer i think, but is in need of a rebuild (lots of backlash), so if you are wrecking your car for parts but can't be bothered pulling everything apart let me know with what you are offering.
Even is bushes are shagged, i may still be interested.
Cheers
Rob
P.s i have looked into fitting pineapples or metal collars, they are not what i am after don't think they will fix my problem.
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 馃檪  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
