Item Summary: 18inch V35 Nissan wheel/tyres... CHEAP V35 Skyline 18inch RIms, Bridgestone tyres. only $600
Asking Price: 600
Delivery Methods: PickUp
Contact Info: [email protected] or P.M.
Extra Information:
I'm selling these V35 Nissan Skyline rims and tyres as I've now sold the car. These are off the 2-door coupe 350GT version from 2004.
Common 5x114 stud pattern which will fit a lot of cars.
4 x Rims and Tyres
2 x Bridgestone Potenzas 225/45/18 (approx 50-60% tread)
2 x Bridgestone Playz 225/45/18 (approx 80-85% tread)
All tread wear is even and would easily pass RWC inspection.
These tyres retail for $250 each when new.
Rims are all straight with NO BUCKLES
only 1 rims has quite bad gutter rash (see pic) other rims a very good with only minor marks.
CHEAP for 18s.. grab a bargain
  • 5 months later...
are the rears larger than fronts of same all round usualy the v35 have slightly larger rears eg FRONTS: 18" x 8" +30 Offset - REAR: 18" x 8.5" +33 Offset
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
