not everyones got mad skills like you bubba :happy:
25 with box drive in drive out 6k (stock)
30 drive in drive out 12-15k (forged)
budget another 6k+ for a turbo setup and 2-3k for fuel then you should be right
not everyones got mad skills like you bubba :ninja:
:happy:
The latest iteration of my 30 is up around R32Drivers estimates.. what with brand new Garrett turbo, 6boost manifold, 50mm gate, 1000cc injectors, stronger internals etc etc.
500rwhp ain't cheap :P
Edited by bubba
If you want to complete the 26 conversion I'd budget near the $10k mark once you changed your gearbox, clutch and all minor bits and pieces.
Whats a 26dett go for these days with wire , ecu n afms ?
Bubba refrain from posting about your rb30 dreams and I will reward you with a carton of emu export.
Dreams schmeams.. they are so close to being a reality that it's going to cost me more money already lol
Export.. with Jacks you might have a better chance :D
hey guys thanks for all your help ;) im goin with the rb25. now i just done no which one to get the s2 33 or the 34. i was told by hyperdrive the 34 neo was better but i dont no? i wanted to see what u gurus rekon. and ill be changing the gear box aswell so im guessing ill be getting a halfcut does anyone no roughly one will set me back
thanks boys
As soon as my motor blows in my 32, im gonna drop a 25 neo in mine... how much work is it??? close to a straight swap with the 20? same engine mounts, etc???
i had a search but cant find any build threads on ppl that have done it...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
