hey guys
i have a rb26 it has 700cc injectors power fc rb25 afms ect.. i had hks gtss turbos on it before i took the turbos off to upgrade the car was tuned and running fine not one miss ect... now ive installed twin high mount td05s and it wont start, in know it wont run perfect if if was to start but it wont start? could it be the plugs? theres no spark coming from the plugs but theres none from the coil packs either?
https://www.sau.com.au/forums/topic/315826-rb26-wont-start-after-turbo-upgrade/
If your not getting any spark then you need to check why, that will be your problem.
When i first started my Silvia after rebuilding the engine it took a bit before it started and actually ran nicely as the inlet manifold had been sitting around all that time and i hadn't cleaned the injectors, (lazy i know) so i presumed that was the reason why as it could of had some stale fuel in there,
But if your not getting any spark you need to find out why first check all your connectors etc
As above, check that the crank angle sensor is working (test it out of the car to see if you can get spark). Obviously check that everything is plugged in, but start at the CAS and work your way back towards the ECU. Make sure you have fuel etc.
Yeah mate, if you're not getting spark you're never going to start the engine =P as the previous kids mentioned check the loom and connections, also check the grounding on the loom. If you have an ignitor module check that. Bust out the multimeter and check that you are getting power and signal properly to the pins back to the ecu if need be, you gotta find out why. Obviously check the ignition =P
As there's no spark from the coils it means it's not the plugs too, it's at or most likely before the coils (before if all coils aren't firing pretty much)
Good luck!
Edited by WhatBrake
ok just quick question i pulled the coil packs out and put the spark plug in the coil and grounded the plug and no spark (not sure if stuff plug or no spark) but when cranking it if i look into the coil pack should there be spark coming from them even tho its not grounded and no plug?
The plug should be near a ground metal and when you crank it there should be spark from the plug not form the coil. If no spark , plugs can be bad and also check your coils to.
given youve done a lot of work, check the basics
check all wires and sensors, check all basic engine functions, check power, check plugs etc
check ETC, SENSOR SW CHECK on the hand controller for sensors with black names (highlighted)
after you;ve done all that, run a re-check of everything and then isolate
air, fuel, spark
if you have all 3 it should start and crank over
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
