Its time for me to depart with my skyline as i need the money to purchase a home. This car is quick and sleak and will turn heads a mile away. So here the list of mods:
1993/94 R33 GTS-T M SPEC (Original)
2.5L Turbo, DOHC, 24 VALUE
Manual transmission with short shift
Metallic Silver
Low KM
* Black Widow Paging Alarm with Immobilser and Central Locking
* FULL GTR BODY KIT - Front Bar/ Grill / Rear Bar/Side Skirts & Pod
* GTR Dash Cluster Fitted on car but Standard R33 Cluster with white dials is
included with sale.
* GTR Centre Gagues - not installed yet
* Custom Silver Dash Surround
* Sparco Gear Knob
* 5'' APC Tacho
* Boost Gague - 7 Colors & Oil Temp Gauge on Pilar
* Custom GTR Style Front Mount Intercooler - Twin end tanks
* Wheels; take your pick - 17'' Chrome wheels or 16'' Standard r33 Wheels
* Blitz Duel Drive BOV
* Boost Controller Value set at 12PSI
* Snap on seat covers
* Oil Catch Can
* Nismo Heat Shield and Simota Air Filter POD
* 3'' Dump Pipe / 3'' High Flow Cat / 3'' Cannon muffler with 5'' Tip
* Front Sway Bar
* Custom Number PLATES - not included with car
* Standard Japanese Stereo will come with car
$20K ,without RWC, prefer melbourne buyers, i live on the west side of
melbourne.
Call me on 0412-402-283 if interested or PM me.
https://www.sau.com.au/forums/topic/31584-mildly-modified-r33-gts-t-4-sale/
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
