lol! 30cm... thats about the same length as a cat convertor eh!
no, I'm running a HKS cat - last place that did the previous system (3 inch) stuffed my 3.5 and are no longer in business. I need a short section to join the cat back and rear (muffler) section. it is a Buddy Club Spec II and can have the rear section detached for track/ drag work.
I'm surprised the place in fyshwick right near commonwealth bank doesn't have any...I know they won't weld on flanges for you, but they will sell you all the parts...assuming shell is right :D
powertone - have tried them, 3.5 stainless is an unusual size apparently...
riiiight.
Well I know I specifically asked for 3.5" stainless with flanges and they said they don't do "that kind of thing" but could sell me everything minus welding it up...ah well
everyone I spoke to said they may have mild steel stocked, but they had to buy the stainless in 3 meter lengths. given I only wanted a short section, they were not interested.
I'm not 100% mine was stainless but if it is I might be able to help you out Dan.
Will check tomorrow.
Cheers Kat, I'm getting to the point where I am thinking of just supplementing with mild steel... I have a track battle against a hot s4 and elise comming up and can't pull a no show :happy:
i have some its polished cost me 120 for a meter from the exhaust shop mitchell should be half of it left.
Hi Cameron, if you have any I'd appreciate if you can let me know!
$50 for it all DAN00H then you and trozzle can sort the rest out. You can come pick it up from Queanbeyan anytime tonight or tomorrow. PM me your number and ill send you my address.
Edited by cameron187
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
