Ive had this thing in my car since I bought it. The guy I bought it from had it set to ROUGHLY 14psi but it would over boost. Ive been playing around with settings for what, 3 months? And still can't get it to work properly.
I had it at one point set to 20%, 5%, 11psi, 14psi, 15% but the piece of shit wont let me hold boost. It goes up and drops, up and drops. I managed at one point to get it to work without hitting the limiter but it would only work on low boost.
Ive tried literally every set of settings I could find to get the thing to run 14psi. The current settings I'm using which I got from some UK skyline forum(and are good for 1bar/14psi) are 44%, 25%, 11.5psi, 15psi, 20%.
Ok so my limiter is set to 15% yet it will still boost to 16psi peak... SOMEONE HELP ME BEFORE I TEAR THIS THING OUT OF MY CAR!
I need settings. Ill put my engine specs here.
NEW turbo with the latest Garrett 3071 ball bearing turbine
Nismo 550cc injectors
Z32 AFM
Nismo Fuel pressure regulator
Trust profec B spec 2 electronic boost controller
Apexi Power FC
Front mount intercooler with custom aluminium piping
Kakimoto catback exhaust
Stainless steel dump pipe
High flow cat
Tomei Adjustable exhaust cam gear
Bosch 040 fuel pump
I dont need links to how to sites. I NEED SETTINGS!!!
I figured that but 1.7psi over the limiter. I was losing traction and straight away backed off because I knew it was too high. My car's high boost is designed to run 16 - 17 psi but its not tuned for that level yet so I'm trying to keep it safe and healthy. I need someone to monitor my boost gauge so I can properly get some WOT and see what boost I maintain.
you cant copy other peoples settings, its different for every car.
start with the gain and set gain set as low as they go, and set the limiter 3-4psi above your target boost and the % limiter thing down low. then start winding the boost up til you reach close to your target. then wind in gain until it spikes then back it off a touch. after all that set the start boost (set gain) to 2-3psi below your target boost, if it spikes set it a bit lower.
if all else fails, find somewhere in your area who knows what they're doing to have a look for you
Edited by JonnoHR31
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
