Got a reply from QLD Transport:
|Engineering Instructions|Vehicle Accesories | |
Date Of 17/04/2 Date Of 17/04/20 No VA.06.04.0 Replaces/A
Issue: 002 Effect: 02 : 2 mends:
It has come to the notice of the Vehicle Safety and Industry Reform Section
that a common modification to vehicles equipped with a turbo-charger
installation is the fitting of an intercooler and a blow off valve.
Forced induction methods such as turbo-charging or super-charging have the
potential to substantially increase the power and performance of a motor
vehicle.
Apart from the engine itself, turbo-charging or super-charging affects four
main vehicle systems. These are exhaust emission controls, vehicle noise
suppression systems, braking system performance and driveline components.
Option 3 of Section LA of the Code of Practice (Light Motor Vehicles)
permits the fitting of turbo-charged and super-charged engines to light
motor vehicles in accordance with Schedule B of Section LA. A part of this
approval requires that a “Safety Upgrade” of the vehicle is implemented in
order to provide for the increase in vehicle performance.
Braking system performance and driveline components are addressed in the
upgrade requirements. Additionally, the modified vehicle must continue to
comply with the Australian Design Rules relating to emission controls and
noise levels to which it was originally constructed.
Whilst it is recognised that a large number of the vehicles referred to in
this instruction are factory fitted with a turbo-charger or super-charger
installation, considerable modifications are carried out to install the
intercooler, blow off valve and associated pipe work. The installation of
these components is acceptable, if fitted in accordance with good
engineering practice, i.e. it should not significantly affect the noise and
emission levels of the vehicle.
Installation of blow off valves/intercoolers are regarded as accessories
and do not require approval under Section LA of the Code of Practice (Light
Motor Vehicles). However, a number of vehicle owners are installing
additional “whistles” to the blow off valves (or alternative blow off
valves with whistles). This procedure has attracted Queensland Police
Service attention. A number of infringement notices have been issued to
vehicle owners for, it is understood, excessive vehicle noise. Whilst the
blow off valve in an unmodified state is of little concern, valves fitted
with a “whistle” attachment can be quite loud.
The Transport Operations (Road Use Management – Vehicle Standards and
Safety) Regulation 1999 requires that a person must not drive a motor
vehicle on a road if the vehicle’s silencing device has been modified so as
to reduce, or be likely to reduce, the effectiveness of the device. As
such, the silencing devices fitted to these vehicles have not been modified
and the noise is not attributed to the exhaust system.
The Transport Operations (Road Use Management-Road Rules) Regulation 1999
raises issues in relation to devices fitted to motor vehicles and excessive
noise emitted from motor vehicles, and is as follows:
Making unnecessary noise or smoke
S 291 (1) A person must not:
(a) start a vehicle, or drive a vehicle, in a way that makes unnecessary
noise or smoke; or
(B) wilfully start a vehicle, or drive a vehicle, in a way that makes
unnecessary noise or smoke.
Example of subsection (1)(a):
Driving a vehicle in a way that causes noise or smoke because of:
(a) disrepair of the vehicle; or
(B) the way the vehicle is loaded; or
© the condition, construction or adjustment of the vehicle’s engine or
other equipment.
Example of subsection (1)(B):
Driving a vehicle in a way that causes noise or smoke by wilfully and
unnecessarily causing the wheels of the vehicle to lose traction and spin
on the road surface.
S 291 (2) A person must not drive a vehicle to which a noisy instrument
is attached or on which a noisy instrument is used.
S 291 (3) The driver of a vehicle or a passenger in or on the vehicle must
not:
(a) ring a bell or sound a horn, except a horn or similar warning device
under section 224; or
(B) play or use a noisy instrument.
It would seem appropriate that the Road Rules legislation is relevant to
vehicles equipped with these devices and which are modified to allow
excessive noise to be emitted. The Queensland Police Service should be
utilizing the Road Rules to enforce the issue, and, the owner would need to
remove the device to avoid continually being issued with infringement
notices.
Inspectors Action:
Transport Inspectors are advised not to issue Defect Notices solely for the
reason of a vehicle being fitted with an intercooler or a blow off valve.
Any enquiries relative to this matter may be referred to the Road Use
Business Management Group on telephone number (07) 3253 4851 or (07) 3253
4778. Inspectors should telephone (07) 3253 4778 or 4308 for additional
information.
But have been talking to people with 600hp+ GT-R's running with stock BOV and they dont have any probs running with 1-2bar boost, so I'll stick with my stock :-)
Thanks guys/gals for all the info though, very educational!
Ska
  • Replies 62
Ska - Thanks for the post - really good stuff.
LOL "Whistles" LOL Where can I get a "Whistle BOV" ???
So it looks like their main concern is the noise, although they also mention the risk or the emisions changing....
I suppose this may be (one of) the reasons why pods are illegal in some states too. Eg. noise...
Good to see intercoolers are OK :)
Jayson
Yeap seems that if you get really loud after market BOV then it is noise pollution, but really after doing a lot of research on BOV's and seeing for myself a couple of R33 and R34's running big after market turbos 1-2bar and both having stock BOV I really am convinced that my stock R33 can do without, I'd much rather put the money I was going to spend on it into a 3inch cat back zaust!
