Hi, Guys,
i really need help with this one.... the Suspension guys have NO F'n clue lol...
when driving and going over bumps/ uneaven roads, there is a clunking noise coming from the front wheels.
have taken it to a number of suspension places to have a look and no idea. one said its the sway bar link arm connector,
we changed this and still making noise?
PLS HELP!!! its driving me insane...
thanks
Ana
https://www.sau.com.au/forums/topic/315860-m35-clunking-noise/
either dead shocks, a stuffed bush, CV, engine mount, loose exhaust mount, the list goes on!
is it coming from the left or right side? if you go over a speed bump, does it happen when you hit the bump, or when you have 'landed' on the other side?
if a suspension/front end specialist cant find the problem. take it elsewhere :thumbsup:
happens when landing , i think.
can feel the bump/clunk thru the brake and accelerator when driving.
has been checked over by pedders (but has not been shaken on the machine)
I had something that sounded similar when driving slow over uneven ground.
Getting all the fiddly bits in the front end cleaned and re-lubed fixed it.
Mechanic said everything had dried up and wasn't moving properly.
No parts required.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
