Hey guys,
Seeing as we have a 1/4 mile thread thought i'd chuck this up as its more of a real world performance benchmark and i'm intrigued as to what the quicker stags are getting down to
Its nice and easy if you've got an ecutalk or a boost controller that does 0-100's
use a format like this:
Model:
Mods:
Power:
->0-100 Time:
So mine is:
Model: S2 RS4S
Mods: Turbo back exhaust, constant high boost mode
Power: 137 awkw (from prev owner, was running 7psi but is now running 10)
->0-100 Time: 5.65 as read from the ecutalk (with a quite a bit of clutch slip)
Cheers, Tom
https://www.sau.com.au/forums/topic/315900-stagea-0-100-times/
So mine is:
Model: S2 RS4S
Cheers, Tom
O-100 in 5.65 - I should check your reading
Edited by RSVFOURUK
yeah my speedo does read a tiny bit under, but probably still a sub 6 sec time
did also launch from about 5k rpm
lets see some more times, most boost controllers have these kind of functions if set up correctly
Bear in mind RSFOURUK that most of the world uses km/hr not miles/hour. But it still looks a bit quick to me.
Yes sorry about that
The 260RS was supposed to do 0-60mph (100kmph is 62,5mph) in 6 seconds so 5.65 would be a fair bit quicker.
Another thing to keep in mind is that Stagea speedos read high... usually by 7-10% :(
Not sure how the factory measure their 0-100kph times, but a 0-110 speedo reading time would give a more accurate 0-100 real world time... if that makes sense :)
blazt tells me mine does 6.3 on a good slip launch from 4 grand . cat back front mount 0.65 bar . half a tank and my 100+ kg
are you going into third or limiting 2nd? could cut my time if i let it hit the limiter in 2nd
There's a program I've got on my iPhone that measures acceleration, braking, g-forces (on a skidpan or during acceleration/braking) and approximate power outputs.
It's called Dynolicious, here's a link...
I haven't had a chance to use it yet because I like owning a car and having a licence and dont' want to risk either of those by "practicing" on the road, so maybe at the next track day or skid pan day I'll try them out.
The gtech bangers are quite good, used to sell them and trial used one, was pretty close to the money on a friends tt 300zx we are talking about 5 years ago and have no idea what model, from memory they were about 400bucks to buy
Or just use the stop watch on your phone.
if you've got a digital camera that takes video you can use that, there are bits of software about that let you go through frame by frame and you can work out the exact point when you hit 100
let see some times ppl
mine was like 3.?? (cant remember exact number, but was measured with gtech) when i did it years ago with the old motor setup, it did a 11.1 @128mph on the gtech on same run (street tyres on the street with stock gtr manual box). 560hp at wheels, and pretty modified (too much to list)
Edited by unique1
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
