We were all talking about the R34 GT-R that had 380,000kms on auction last week (or was that 2 weeks ago). Well it was sold today for 1,560,000 yen which equates to about $18,500 in aussie dollars. Then add the usual FOB, freight, taxes, compliance, and other misc fees and you will have yourself a GT-R for under 30 grand.
I can't wait until she lands on our shores, so everyone stay tuned for this baby.
http://ayp5.nihoncars.com/cars/37815341/0/...T__sl__6yyn.jpg
http://ayp5.nihoncars.com/cars/37815341/0/..._sl__6yy%3F.jpg
http://ayp5.nihoncars.com/cars/37815341/0/...T__sl__63y3.jpg
https://www.sau.com.au/forums/topic/315902-the-380000km-r34-gt-r-sold/
Other pearlers worth mentioning as well.
2001 M Spec (well it's claimed to be but I doubt it's the real deal), 165,000kms, grade 3.5/B --- sold for 2 mil yen
http://ayp5.nihoncars.com/cars/37792099/0/..._sl__nynO3l.JPG
http://ayp5.nihoncars.com/cars/37792099/0/..._sl__nynO3x.JPG
That raises a point; how often do r34's come up with mechanical issues?
Eg a blown motor (bearings or similar), surely they would be priced close to this 380,000k one?
I saw a rolled NUR Spec in Millenium Jade at Nagoya a few months ago. There was not an undamaged panel on the car and it sold for 1.1mill. Prices lately are just bizarre, absolutely all over the place.
Rolled? Bloody hell, what a waste.
I mean one thats structurally fine, clean enough inside etc but a blown motor, or a blown gearbox (or just no motor and box altogether)?
Motors over here are easy enough to buy, or just build :ermm:
As you can tell by the prices they pull at auction, if a 34 has a blown engine or box it will simply be replaced or repaired.
It's not like they're at a value whereby if the engine is blown they're worth nothing. So, if you were to find one with a blown donk, it would likely only be cheaper by the value of a rebuild engine.
Even if you were to find one like this, the extra shipping costs due to it not being drivable with outweigh any real benefit.
I remember that one, I think I put 500,000 or something on it just for the engine/drivertrain...
THese generally don't make it to auction, they get bought by dealers or fixed by the owners. Plenty of rattly 32/33s go through but generally the type of person who owns a 34 has the money to fix the car before selling it.
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
