yep, already too many of them involved in accidents.. and then being classified as "high performance cars" and then the cops are after them..
i mean.. sure you can drive like there is no tomorrow.. but think about us :D... i bet when i get the money to have a good car that -might- be "hi performance" they would be outlawed..
https://www.sau.com.au/forums/topic/31595--/#findComment-638393
yep i was been a fool b4
so i learn it the hard way
i mean...its sad to see others to learn the hard way as well...
i call him moron coz he didnt estimate the power of the car...and try to be a hero maybe...what u get out of it is pain and lost....not worth it...
if u wanna keep it...treasure it...
https://www.sau.com.au/forums/topic/31595--/#findComment-639571
ST.KILDA ROAD as everyone knows is very busy and considering not one of you saw the actual accident i consider u take time out and fink dat maybe it wasnt his fault!!! i dont know anyone that would drive an r34 recklessly, unless off coarse der loaded in which case i belive dey can drive it how evah dey want, crash it wen evah dey want, as long as der not endangering anyone else or their own lives!!! but any way lets not all jump to conclusion and just hope the driver n passangers of the car are ok da car will get fixed im sure....... :goddam: ohhh and by the way if it was there fault n if they were driving recklessly then vikii ur right their MORONS :rofl:
https://www.sau.com.au/forums/topic/31595--/#findComment-639969
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
