Thinking of selling ... r34 coupe auto 2000 with 81000ks stock as... has sunroof.. have no mods what so ever.. not even a ttimer... I was thinking around 23k
Interior excellelnt... paintwork not pad but could be better.
Engine very smooth, turbo on stock boost and spools quick and not noisily so should have plenty of life.
reason fuel price is killing me.. love the car tho..
https://www.sau.com.au/forums/topic/315952-whats-an-r34-worth-in-wa/
You wont get 23k for it. Maybe worth 15-17k, has no mods...
hm.. it is turbo tho.. yr 2000.. most cars I see are 1998 and high kays .. I guess some people want moded and thrashed to buggery cars and then some want a clean start..
I'm guessing most people here want mods and manual.
do you mean a 1998 or a 2000
Same sh!t man, 2 years won't make 5k difference in price...
Unfortunately your car is auto, so that makes it a tad undesirable...
Have a look on carsales and gauge your price decision on that...
Most 34s there are going for 18-25 depending on trans, turbo or not, kms, condition etc...
Good point. Found same year better car on carsales going for 22k with a stereo so I'm gona do 19k.
Yeah if it was me personally, I'd start at 20k, you can always drop it down if you're not getting any bites!
Autoworx sell R34's manual turbo for 20k a pop... So 18ish with a series 2 model and sunroof should be alright..
I just checked their site, yes manual... none of their cars are yr 2000 and thus are not series 2 and they don't have any lol.. must be in high demand.
one had a 320k spedo that already clocked 76k.. wonder how much one would trust the km's on a car like that. its probably done over 100k kms easy.. but u never know ...
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
