Hi all,
We're building a new car for the Queensland Time Attack series. Starting with a pretty much stock 1999 R34, we are adding the following bits to get the output up to around 300-350HP ATW.
We started the build yesterday (08/04/10) and hope to get it all finished in the next few weeks.
Here is the shopping list;
HKS GT-RS Turbo kit
Apexi Power FC
HKS EVC Boost Control
Nismo 480cc injectors
Nismo Spark Plugs
Nismo High Pressure Fuel Pump
Nismo Fuel Pressure Regulator
Nismo Coppermix Clutch
Nismo GT LSD TT 2-way
and here is the progress so far.
08/04/10
Dropping the car off to Ivan at Hi Power Racing
On the dyno for the first run
Dyno Sheet
Video of the run here
09/04/10
Clutch is in and Nismo LSD has been fitted. Turbo goes in early next week.
https://www.sau.com.au/forums/topic/315975-project-r34/
  • Replies 92
Finished in a few Weeks!!!!!
Nice, gotta love a quick turnaround.
Some nice parts you have there, Looking forward to watching the progress.
Is it going to be a track only car?
What times are you hoping you will get out of her?
https://www.sau.com.au/forums/topic/315975-project-r34/#findComment-5173679
nice work.. will be watching ur progress
isn't the turbo too big for the 350hp atw goal? also ur dyno run was 205hp stock??
edit: my bad, ur sig had r34 gtr so i assumed that was the car u were doing the mods to..
Edited by BWRGTR
https://www.sau.com.au/forums/topic/315975-project-r34/#findComment-5173714
Thanks for the support guys! We are planning to get to the injectors and fit up the turbo this afternoon. Pics to follow!
Duncan1 - We will keep it road registered and we hope to break into the sub-one minute bracket at QR!
BWRGTR - Yeah, the Bayside Blue GT-R we are pretty happy with, no new mods to it at the moment. The 205HP ATW also seemed a bit low, but we did hit the speed cut.
Luke_ENR34 - You might have to put a bit more work into your proposal! :D
https://www.sau.com.au/forums/topic/315975-project-r34/#findComment-5175800
Luke_ENR34 - You might have to put a bit more work into your proposal! :action-smiley-069:
hmm yeh 205hp is very low i think, 206kw stock (not at the wheels given, but thats ~280hp) vs rb20 165kw(~220hp) and my old 32 gtst made 200hp atw with a 3inch exhaust, fMIC and a pod filter
does the car still have stock exhaust ?
otherwise great build ! good to see some people still go for a nice amount of power instead of chasing huge numbers :wub:
I much preffer a bit less power but more response, linear delivery
https://www.sau.com.au/forums/topic/315975-project-r34/#findComment-5176827
Day 3 12/4/10
So while I was at the workshop yesterday, the CF card in my camera exploded. Luckily, my trusty camera phone
was there for backup.
LSD & gearbox are now bolted back in, factory turbo is out & HKS GT-RS is in!
Turbo out
Old & new side by side
Turbo fitted
https://www.sau.com.au/forums/topic/315975-project-r34/#findComment-5177565
are you guys going to remove HICAS?
We're leaving the HICAS alone at the moment, we'll take it for a spin once it's all together and see how it it feels. We'll make a decision after that if it's going to go.
https://www.sau.com.au/forums/topic/315975-project-r34/#findComment-5177603
Should be a nice car once its complete. but I am suprised at the choice on the Little GT-RS when QR is really all about straight line poke.
What suspension / tyres etc are you guys gonna run?
Zebra, we are going for strong and reliable, rather than going for the highest output. It doesn't have to be the quickest car out there, just enough to have some fun.
Leaving the suspension alone at the moment, it has a set of racing logic coilovers now and we will probably make a few changes, but nothing yet. The wheels will be LM GT4 18 x 10 all round and as far as tyre choice, we use either Nexen, Corsa or Achilles depending on the day.
Edited by Link Auto
https://www.sau.com.au/forums/topic/315975-project-r34/#findComment-5179928
I like your thinking with that.
Are you not going to run proper semi-slicks for the track?
Its just that you said you wanted sub 60secs on the sprint track...which is pretty damn fast.
https://www.sau.com.au/forums/topic/315975-project-r34/#findComment-5179945
Sorry mate, I didn't include Falken Azenis that we use at track days! On standard rubber in its previous form, we have managed a 1.06.03 from this car, so we are hoping that sub 60 is within reach. If everything falls into place, it will be ready for the next track day to find out!
https://www.sau.com.au/forums/topic/315975-project-r34/#findComment-5180039
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
