Day 6 - 15/4/10
1 can of VHT = stealth intercooler :)
Intercooler is all plumbed in now, the injectors are next, also got the Pivot gauges installed
The guys were also tuning the S15 for the upcoming World Time Attack, such a beast.
  • Replies 92
Good to see another skyline being done up for racing!
Dont want to rain on your parade for the times, but zebra is right. Its easy to get down to low 60's, to push past that and into sub 60's it jumps up exponentially. Not just in power, but suspension, tyre size and compound, cars weight, brake setup and a whole myriad of other things. Good luck to you though, hopefully you do get there. Ive found that if you go out there just to have fun and not worry about your times, you end up doing your best ones without it feeling like you were trying! Its great!
Hopefully will see you out there.
Hi 33_racer, thanks for your advice. We have no illusions about the cost and commitment that it takes to really go fast. To be honest, a 59.99 would be perfect! There is no way that we will be the quickest, as this car will remain road registered, but the Red 4 door GT-T we were using previously was almost totally stock and getting smashed on the straights. Hopefully, this will just allow us to be a little more competitive.
Back to the build - The Apexi Power FC finally turned up!
IT'S ALIVE!
:D
Day 7 - 16/4/10
Everything is back together and the Power FC is in! Terry calculated a basic tune and she kicked over first time!!!
Unfortunately we can't get it on the dyno today, but come Monday, we will be on the rollers and find out what gains we made!
Day 9 - 20/04/10
330HP ATW!!!
Here are the dyno sheets, the first three show the actual tune with a steady power curve. The last one is in shootout mode, just going for big numbers. Note the wheelspin at 4000RPM on the last sheet.
On the final pic, the green line shows where we started and the red line is the current output. Pretty happy with that.
unless the guy was braking then i'd say the rollers have more resistance judging by how fast the car slowed down.
Anyways iv been for a ride in a 300hp r33 and that was quick enough to impress me lol.
Have you thought about getting a lightened flywheel?
Edited by R34 -_-
my car with over 300kw doesnt accelerate that fast in 4th from low revs. both the dyno and the car have brakes that the operator can use to slow it down after the run.
    • They're so beautiful 馃槏
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I鈥檝e also seen them explode from the binding
