  • Replies 92
Sorry mate, I didn't include Falken Azenis that we use at track days! On standard rubber in its previous form, we have managed a 1.06.03 from this car, so we are hoping that sub 60 is within reach. If everything falls into place, it will be ready for the next track day to find out!
I have to agree with the others, sub 60 sec is a big commitment in a road reg car even with the best conditions. Good luck with the project. I will be watching with interest.
Been sourcing the kit for the 34 and just getting used to the new set up..
Also have purchased the new bonnet. Gone with the ADR approve Blits one. Should arrive tomorrow!
Also going to QR for Time Attack tomorrow, be our first chance to really wind it up. Be interesting to see how it goes.
After a shakedown at QR, we found that the factory inlet to the turbo was heating up and constricting, limiting air flow. So Ivan and the guys at Hi Power Racing manufactured a new inlet pipe and here are the results.
To say that we are pleased would be a massive understatement!
377.8HP @1.5 bar. :P
We have also started on the suspension, replacing the links & bushes with Nismo items.
The red front bar is just to keep it all legal until the new one arrives!
Snozzle, we pinched that cluster out of our red R34 and it came like that from Japan, so sorry mate - no extra details on that one unfortunately!
The boost is all over the place yet such a good figure of power :)
Ivan has explained to me that the boost drop is due to us retaining the standard manifold - that keeps things interesting!
That was also just a run in Shootout mode to see what we could get out of it, here are the tuning runs.
As in standard exhaust manifold? I'm running the standard exhaust manifold on my GTRS and it holds boost fine with a slight drop towards redline of a couple of psi. With your HKS EVC I would have thought you could get it to hold perfectly.
Is there any adjustability in the Nismo arms?
It doesnt look like there is any at all.
No adjustment in the Nismo arms, the geometry of the setup is designed for performance driving. Trying to get a balance between performance and comfort, while keeping the car road legal.
have you got any runs with the AFR's on it?
No runs with the AFR's that I have seen, but the guys at HPR should have them somewhere. I'll try to track them down.
Got the car back and just went for the first run with the extra neddies and new suspension components... is good.
It felt quick before, but you get a really good shove from it now. Even more importantly, you are coming on boost at 2800rpm and it winds straight out to 1.6bar and the engine just spins out to the redline.
The whole car feels very solid mid corner and it particularly impressive coming out the other side, really getting the power through to the ground.
Will be getting on to the bodywork next...
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
