  • Replies 92
Sorry mate, I didn't include Falken Azenis that we use at track days! On standard rubber in its previous form, we have managed a 1.06.03 from this car, so we are hoping that sub 60 is within reach. If everything falls into place, it will be ready for the next track day to find out!
I have to agree with the others, sub 60 sec is a big commitment in a road reg car even with the best conditions. Good luck with the project. I will be watching with interest.
Been sourcing the kit for the 34 and just getting used to the new set up..
Also have purchased the new bonnet. Gone with the ADR approve Blits one. Should arrive tomorrow!
Also going to QR for Time Attack tomorrow, be our first chance to really wind it up. Be interesting to see how it goes.
After a shakedown at QR, we found that the factory inlet to the turbo was heating up and constricting, limiting air flow. So Ivan and the guys at Hi Power Racing manufactured a new inlet pipe and here are the results.
To say that we are pleased would be a massive understatement!
377.8HP @1.5 bar. :P
We have also started on the suspension, replacing the links & bushes with Nismo items.
The red front bar is just to keep it all legal until the new one arrives!
Snozzle, we pinched that cluster out of our red R34 and it came like that from Japan, so sorry mate - no extra details on that one unfortunately!
The boost is all over the place yet such a good figure of power :)
Ivan has explained to me that the boost drop is due to us retaining the standard manifold - that keeps things interesting!
That was also just a run in Shootout mode to see what we could get out of it, here are the tuning runs.
As in standard exhaust manifold? I'm running the standard exhaust manifold on my GTRS and it holds boost fine with a slight drop towards redline of a couple of psi. With your HKS EVC I would have thought you could get it to hold perfectly.
Is there any adjustability in the Nismo arms?
It doesnt look like there is any at all.
No adjustment in the Nismo arms, the geometry of the setup is designed for performance driving. Trying to get a balance between performance and comfort, while keeping the car road legal.
have you got any runs with the AFR's on it?
No runs with the AFR's that I have seen, but the guys at HPR should have them somewhere. I'll try to track them down.
Got the car back and just went for the first run with the extra neddies and new suspension components... is good.
It felt quick before, but you get a really good shove from it now. Even more importantly, you are coming on boost at 2800rpm and it winds straight out to 1.6bar and the engine just spins out to the redline.
The whole car feels very solid mid corner and it particularly impressive coming out the other side, really getting the power through to the ground.
Will be getting on to the bodywork next...
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
