  • Replies 92
hay buddy
i love ur nismo suspension arms
if i could ask where u got it from and the price u paid for all of it i would really appreciate it
pm if u prefer
ive bought and used the nismo arms before. I had the whole set front and rear in my R32 gtr. A little bit pricey for what they are, which is essentially the stock arms painted silver with strengthened nismo bushes. If you must go down this route you are better off just buying the strengthened nismo bushes and have them pushed into your standard arms. there are a few extra tack welds along the standard bracing in some of the arms for that little bit extra reinforcement, but nothing you couldnt do yourself. The great thing about nismo bushes is that they are still rubber which although strengthened, will not be as harsh as a rose joint, but still does offer a slightly better feel than the standard bushes without sacraficing too much comfort. This is a good choice for a street car with no legality issues. If this is not a concern and you head to down to the track every once in a while, i think the ikeya formula arms are hard to beat for direct response and feel, with adjustability for a circuit setup if required. Or alternatively you can dial in a setting that allows for lesser tyre wear on the tyres (especially the rear) for regular road driviing. The The nismo arms, like the standard arms are fixed into a position where it causes excessive wear on the inner rears. Although great for traction when youre giving it some around corners, is not the ideal setup for a road car, especially when youre running an expensive tyre package for daily driving. With adjustable arms, you could dial some or all of this out to give your tyres a more even wear and allowing your them a longer life. The ikea formula arms may be a little more expensive, but for that little extra over the nismo arms, the gains far outweigh the extra cost. Whatever you end up choosing im sure ivan from hi power can help you out! One thing though DO NOT BUY CHINESE ARMS!
Edited by AtomicBomberMan
Wow impressive build up guys cant wait to see it all finished with the kit etc. I was wondering if you could possibly pm me a rough price as to how much the engine mods + labour were as i would love to have the same or similar mods on my 33gtst.
Good luck with getting the times your are after also.
  • 4 weeks later...
Where u end up getting the Z-tune guards from?
Need some for my car in the near future.
We are the Australian importer & distributor of Nismo Competition Parts, so luckily, we had a set out the back :)
If you need a set, you can order them through any authorised dealer.
  • 1 month later...
Halfway through the respray. Rear guards have been flared, Z-Tune guards have been modified to match up with the side skirts, the car should be going into the booth today to finish the body.
Progress pics:
I can't be certain (due to the angle of the photo) but the rear guards don't look that great :wacko: looks like u killed the factory flare line and just went for the bulge look, would of been nicer if it was the same as the GTR rear quarters with the vivid horizontal line
Edited by R34 -_-
Awesome advice-thanks Chris
Top class build up thread Guys at Link- good map for anyone else building up a R34 GTT-well done
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
