  • Replies 92
Sorry mate, I didn't include Falken Azenis that we use at track days! On standard rubber in its previous form, we have managed a 1.06.03 from this car, so we are hoping that sub 60 is within reach. If everything falls into place, it will be ready for the next track day to find out!
I have to agree with the others, sub 60 sec is a big commitment in a road reg car even with the best conditions. Good luck with the project. I will be watching with interest.
Been sourcing the kit for the 34 and just getting used to the new set up..
Also have purchased the new bonnet. Gone with the ADR approve Blits one. Should arrive tomorrow!
Also going to QR for Time Attack tomorrow, be our first chance to really wind it up. Be interesting to see how it goes.
After a shakedown at QR, we found that the factory inlet to the turbo was heating up and constricting, limiting air flow. So Ivan and the guys at Hi Power Racing manufactured a new inlet pipe and here are the results.
To say that we are pleased would be a massive understatement!
377.8HP @1.5 bar. :P
We have also started on the suspension, replacing the links & bushes with Nismo items.
The red front bar is just to keep it all legal until the new one arrives!
Snozzle, we pinched that cluster out of our red R34 and it came like that from Japan, so sorry mate - no extra details on that one unfortunately!
The boost is all over the place yet such a good figure of power :)
Ivan has explained to me that the boost drop is due to us retaining the standard manifold - that keeps things interesting!
That was also just a run in Shootout mode to see what we could get out of it, here are the tuning runs.
As in standard exhaust manifold? I'm running the standard exhaust manifold on my GTRS and it holds boost fine with a slight drop towards redline of a couple of psi. With your HKS EVC I would have thought you could get it to hold perfectly.
Is there any adjustability in the Nismo arms?
It doesnt look like there is any at all.
No adjustment in the Nismo arms, the geometry of the setup is designed for performance driving. Trying to get a balance between performance and comfort, while keeping the car road legal.
have you got any runs with the AFR's on it?
No runs with the AFR's that I have seen, but the guys at HPR should have them somewhere. I'll try to track them down.
Got the car back and just went for the first run with the extra neddies and new suspension components... is good.
It felt quick before, but you get a really good shove from it now. Even more importantly, you are coming on boost at 2800rpm and it winds straight out to 1.6bar and the engine just spins out to the redline.
The whole car feels very solid mid corner and it particularly impressive coming out the other side, really getting the power through to the ground.
Will be getting on to the bodywork next...
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
