hi all i need to make my rear sunroof seal better... the end closer to the rear of the car isnt coming up flush with the car as well as it should... only needs a few more mm to seal properly.. just need to get in b4 winter sets in ;)
https://www.sau.com.au/forums/topic/316057-adjusting-rear-sunroof-close-heigh/
hi all i need to make my rear sunroof seal better... the end closer to the rear of the car isnt coming up flush with the car as well as it should... only needs a few more mm to seal properly.. just need to get in b4 winter sets in :D
Hello mate,
I had the same problem.
If you take the black plastic trim off of each side you will see the runners that hold the glass and three bolts.
Loosen all three bolts on both sides and then push on the glass gently - ypu will see it lifts. Slide a piece of thin metal stock from the local homeware store between the runners and the glass on each side. One small piece around 10mm long on each end should be enough enough. Tighten the bolts{not too much} and try that. The stock i used was 2mm thick, 10mm wide stainless and this worked a treat as it does not foul the runners and the plastic covers conceal it, but you may need something a little thicker.
Hope this helps and sorry i don't have any photo's. :blink:
Si.
  • Like 1
  • 6 years later...
Old thread, but thought I'd add to it in case others look to this.
I can confirm this works great! I made up some lil shims out of aluminium, easy to cut/file to shape. I made thick ones for the rear and thin ones for the front. Pictures from left to right is the thin, stock one and the thick one. I added the to the bolts from front to rear in the same order, sunroof seals great now :)
Only problem I had was the crappy plastic screw clip on the plastic trim covering the bolts wouldn't loosen, so I just yanked the other end to unclip it and spun it around on the screw clip to move it out of the way
