Factory Made Body Kit And Wheels With Tiers For Gtst R33 S2
Recently installed new body kit and wheels and now ill be moving and i cant take the factory parts with me.
Parts are from a Gt st 2 door r33 series 2 1996
ill be selling all body kits, wheels with tiers and will throw in a new grill to.
if have a good eye you can see handy work that was done to install a inter-cooler
paint chiped off
only used ones to get me from Vic to Adelaide. Still good condition
and the free grill that i got from viva garage
if possible i like it to be over $450 to cover the moving experience
and in Adelaide
if any question just ask
Hey mate, interested in the wheel and grill if you can post them to 3806. How much are you asking for the wheels? If you don't want to post the wheels, then how much for the grill delivered?
Cheers
im still looking for a cheap delivery but the wheels are 300 for the 4 wheels and tyers
Cheers
it looks like around 56 i think, but ill find out when i ring up, close now
Cheers
yea its the original
thread if its the mid of this
its 4mm
360 for both side and wheels with tyres
smart send $75
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
