Hi Guys, I need to clear out my shed as i horde was too many parts, I'll start with a few.
R32 RB26 crank seems good condition - $450
R32 RB26 Bock (main caps girdle etc) std bore slight scores from cracked ring lands - $300
R32 pistons and rods, good cond but always measure small and big ends before use - $150
R32 GTR standard cam shafts - good cond - $180 the pair
R33 RB25 det bottom end, cracked ring land on number 6, good for rebuild otherwise in vgc - $200
R33 RB25 det head, good condition, no inlet or exhaust manifolds or cams good condition - $180
Located in Adelaide, can ship at your expense, I have access to a freight broker.
Edited by GTR1993
https://www.sau.com.au/forums/topic/316092-gtr-parts-for-sale/
I assume the R34 block?
The R32 block was approx 100,000 km
The R34 block was 26,000 km, I have the sump off on an engine stand and you can see it looks brand new.
How much for the R34 Block? pics??
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for ?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for  >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate modern almost all cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
    • Let's be wary though, if cranking is so far off, what else isn't set right? Are the dead times set right, voltage compensation etc?   It definitely sounds like it's cranking fuel issues, and holding flat to the floor is shutting them down, but I'm with Duncan that if nothing was changed in the ECU at all, and then this started, I'd be more thinking a leaking injector.   Do as Duncan said, drop the oil and make sure it's not full of fuel.
    • It actually means give it less throttle.
    • Yeah if the goal is to drive something then modifying a car is a bad idea.
    • Wowee! She looks like a major handful out there Pete!
