Hey guys,
thinking of getting a guage to use up the redundant sensor on the side of the block
r34's came with an oil pressure guage and there is a fitting for it on the side of the block (near the oil filter) i'm guessing its gonna be a fairly common size
so...... whats a more usefull guage?
temp is good because then i will know when the oil is up to temp and not just the coolant
but pressure would also be good to know and more dangerous to the motor if it drops un-noticed
whats everyones take? (just want one gauge because i know i can fit it without a sandwich plate)
cheers, Tom
https://www.sau.com.au/forums/topic/316095-oil-pressure-or-oil-temp/
Go definitely Oil Pressure as it will indicate to you if your oil pump is working or not and also a low oil pressure is indicative of low oil level and it's not what you want. Oil's these days especially if you use synthetic oil can withstand high temp and probably more than what your engine produces.
In conclusion go pressure.
Denis the Menace
mad, someone near me is selling a basic calibre (i know its a cheap shit one but its better than nothing) oil pressure guage for $20 ;)
i'll go it
now i'm just wondering if the stock sender will work with it (pretty sure the 34's had a pressure guage and not a temp)
the gauge should (must) come with the sender.
pressure BTW. it also gives you an indication of oil temp (cold v warm) due to the drop in pressure when the oil warms up. won't tell you about over temp oil of course but water temp is normally a good indicator of oil temp
I have afoot in both camps.
After getting rid of the OEM sound unit I had a nice spot for a din size clusterI have an oil filter relocation unit with both temp and pressure senders fitted. Easy. Also you have the OEM oil can warning light that will tell you if there is low level/pressure. Third spot in the cluster is a voltmeter.
all my din spots are taken up, got an rs4s so i have the [torque,volts,boost] din unit + stereo + air con
not too sure where to mount it tho, running out of room
got a boost gauge on the a pillar already, ecutalk below the head unit (where i should have cup holders but i dont have any :blink:)
got a boost gauge on the a pillar already, ecutalk below the head unit (where i should have cup holders but i dont have any :D)
cup holders would make for an interesting drive with a manual hey :blink: i'd go with the oil pressure one too. are you sure it will work with the stock sender? i have a gauge mounted on the dash next to the pillar, just beside that little air vent thing. i just used some good double sided tape and a gauge cup holder/stand. 2 years and its still holding on. you might be able to get it on the dash beside the pillar gauge and still look good. here's a pic of where i'm talking about , 6th and 15th posts down in this thread LINK
Edited by QWK32
well i thought i had no cup holders cos it was manual but i saw another rs4s the otherday and it had the pop out double ones just above the sig lighter/coin tray
where you have that gauge is exactly where my pillar mounted gauge is but its attached to the pillar
i'll work something out
I use the mearcat pods: oil temp and oil pressure where the clock used to be, and boost guage on the mearcat a-pillar pod. his stuff is awesome, and custom moulded for each type of car...
but how do you tell the time?
got a boost gauge on the a pillar already, ecutalk below the head unit (where i should have cup holders but i dont have any :P)
Blitz DC? can mount on any flat(ish) surface with DS tape.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
