Hmm ok
Does anyone know if the diagonal there to stop the main hoop bending down onto my head in a rollover or to stop it coming in on a side impact
spose i coult make it a X and be covered for both...
Thought id post my question here before starting a new thread :D
I’ve just received a bonds six point bolt in cage for my HR31 and am worried about the position of the diagonal bar on the main hoop.
With the cage assembled, it goes from the driver’s side bottom to the passenger side top.
Is this correct? I had a look in the CAMS manual and from the diagrams it looks like it should go the other way. Will it pass log booking like that?
yeah generally the diagonal in the main hoop goes from top drivers side to bottom passenger side. like you say it stops the hoop crushing in side impact and also protects your noggin in roll over. not sure why it runs the other way but it may be ok, or like you say to be sure you can make an X and be covered no matter what. the downside is the X severely limits access to the back of the cabin.
talk to bond about why the cage is like that. I'm sure they have a good reason.
cheers baron.
on another note, im about to respray the inside of the car and have noticed that most ppl go for white.
wouldn't black or a darker colour be less glary in the sun?
The bits that are actually going to glare (cage, dash etc) are generally painted matt black or covered in floc (mmmm sexy dash).
White in the interior is easy to clean, easy to maintain, easy to find bits in when you drop them :P etc. If you don't like the stark white, then a grey is not too bad either. Mine is done in a gloss grey POR that looks pretty good and is reasonably hard wearing.
the reason many people go white is purely for aesthetics. it looks nice. when you go black you loose all the detail in the interior in a sea of black and it does get hard to find dropped nuts etc. black also gets hot. grey is a good option. always a good idea to paint the cage the same as the interior as it hides it a bit unless you don't care in which case paint any colour you want. :P
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
