Well, my 2000 C34 Stagea finally arrived in South Australia yesterday after 2 months of waiting.
It's a Bayside blue Series 2 Dayz edition.
Auto with only 57000km on the clock.
Dual electric sunroofs, Carbon fibre mirror covers, Carbon fibre 'd' pillar covers, Carbon fibre front lip insert. Full Dayz bodykit.
Nismo 3" exhaust and blitz pod filter, 18*10" rims (Yes officer, they do sit inside the gaurds)
Car goes really well and i'm very happy with it.
EXCEPT.... it has already developed a missfire, very slight at idle but it feels like a fuel cut once you get up to 5000rpm (it still accelerates all the way to redline, just missfires from 5000 thru to 6500), so it gets new iridium plugs on Monday and maybe some coilpacks(hopefully just the plugs fix the issue).
So here it is
https://www.sau.com.au/forums/topic/316128-stagea-has-finally-arrived/
GratZ
Very Nice still look like the day I saw it down at the shop
but still cant understand why it took so dam long but look at it this way you have it now and its good to see more smiles
Enjoy
very nice, and nice colour too, i had the same colour stagea like your and i just bought it 2 weeks ago in Melbourne, but i have AUTOTECH front and MASA side skirt and rear bar. i also got the 18x8 rim , is come with the car. Any chance you can find out what size of the tyre you use? 245/40/18 or 255/40/18? what offset of your rim?
i'm running 235/40r18 tyres stretched onto the 10 inch wide rims. don't know about the offset, the rims have a jap sticker on them but i can't read it for some reason. they sit fairly close to the struts and still hang out the guards on the rear. i'm prety sure that they'd suit a GTR rear end a bit better
very nice
you'll need a nistune ecu to get rid of the :"rich/retard / fuel/boost" cut thingymajigy
upgraded coilpacks wouldnt go astray one day, sparkies use Ngk BP6RE copper .8mm v-gruve, $20 for the 6
then it'd be tuned nice and responsive
all in good time
So here it is
Don't waste your money on the iridium plugs, just use standard ones for $12-14 a set and change them a bit more often
Cars that have iridium plugs that sit around for a few months esp in car yards or waiting to be exported, the plugs get fouled up due to running for short periods of time due to being very rich when cold. Gap them to 0.8mm
i'm a mechanic, so iridium plugs are cheap for me anyway.I always run them in my vehicles. they made a large difference to fuel economy and throttle response in my Suzuki GSR600(plus they were a pain to get to every service) I even run them in the wifes car, they last alot longer than stock plugs. probably have to order some yellow jacket coils on monday if the plugs don't help out.
i'm pretty sure its not rich and retard, cause it misses like crazy at idle sometimes, and it's alot worse when driving in cold, wet weather(it didn't happen in sydney when i test drove it in 30'c weather). plus i'm pretty sure that it is tsill running standard boost. there's no sign of a bleeed valve or anything under the bonnet.
i popped the coil pack cover off last night and gave everything a good coating of silicone spray and it seemed to get a bit better for a little while. hopefully it is only the plugs and coilpacks tho, i've got other stuff to spend my hard earned cash on rather than fault finding on this car.
Edited by gsr600guy
yeah hopefully there will be another stagea cruise coming up soon. i've already used a tank and a half of fuel cruising around and its been washed twice already(damn wet weather)
took it out for a run today to the Mount Alma Mile hillclimb event for a look then looped back thru victor to do a delamere road run home.( i think i may have to remove the speed cut) these things pull really hard up top, even with my missfire issue the car pulled really strong.
now my plans for this couple of weeks are
- plugs, maybe coils
- alarm and immobiliser (so that Just cars will actually cover my insurance)
- remove dodgy jap spec remote start system
- fit my 7 inch dvd touch screen so i can actually listen to the radio
- remove standard speakers and fit some decent splits
- get sa rego
- order new number plates
- get front windows tinted
- remove compliance cat and get hi flow unit fitted
- get power run on the dyno for a baseline for future mods
It needs a bit of lowering in my opinion, but otherwise looks great! Congrats!
yeah it needs to be dropped a bit, prob can only go 1 inch lower tho, the rear rims hang out the gaurds and i don't rally want to wear thru the sidewall of my tyre.
robbie, can you help me please? my stagea is same colour as your, i need a colour code , but from my engine VIN plate siad my colour code is KR4 is my colour code, but people here told me KR4 is sliver colour, so i believe my car was respray in different colour from japan. Can you find out for me what is your colour code please? because i bought a parts from auction yahoo and they want my colour code, thanks you.
colour code is TV2
Bayside blue
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
